ESP-IDF 32bit register SPI read/write
BinaryPoet
Postby BinaryPoet » Mon May 20, 2024 3:33 pm
I am trying to read/write 32 bit registers from stepper driver TMC5240 using a ESP32S3 CPU.
According to stepper DS, the write operation should be performed writing the register address + 0x80 followed by 32 bit register values.
For example, for a write access to the register (VACTUAL), the address byte has to be set to 0x80 + 0x22 = 0xA2, so to write AABBCCDD to this register I should send 0xA2 0xAA 0xBB 0xCC.
The read operation consists in writing the register address followed by 4 bytes of zeros.
Does the 32 bits limit of SPI_TRANS_USE_TXDATA, SPI_TRANS_USE_RXDATA includes also the address?
the following functions does not work, in particular I always read the same value (0x39) from all the registers.
int32_t tmc5240_readInt(TMC5240TypeDef *tmc5240, uint8_t address)
	uint8_t channel = tmc5240->config->channel;
	if (channel < stepperINVALID)
		 esp_err_t err;
		 uint32_t RxDataBuff;
		 uint32_t value = 0;
		 // uint8_t pBuffer2[2];
		 spi_transaction_t spitr = {
		 	      .cmd       = address,
		 	      .length    = 4 * 8,
		 	      .flags     = SPI_TRANS_USE_TXDATA,
		 		  .tx_data = {value},
				  .rx_buffer = &RxDataBuff,
				  .rxlength = 32
		 	      //.user      = (void*) &sensor_ctx,
		 err = spi_device_acquire_bus(m_stepper_cfg[channel].hspi, portMAX_DELAY);
		 if (err != ESP_OK ) printf("SPI ACQ BUS ERROR\n");
		 err = spi_device_transmit(m_stepper_cfg[channel].hspi, &spitr);
		 ESP_ERROR_CHECK(err);
		 if (err != ESP_OK ) printf("SPI READ ERROR address %d\n", address);
		 spi_device_release_bus(m_stepper_cfg[channel].hspi);
		 //if (err != ESP_OK ) printf("SPI ACQ BUS ERROR\n");
		 //uint32_t res = SPI_SWAP_DATA_RX(RxDataBuff, 32);
		 return(RxDataBuff);
	return -1;
void   tmc5240_writeInt(TMC5240TypeDef *tmc5240, uint8_t address, int32_t value)
	esp_err_t err;
	spi_transaction_t t = {
	      .cmd       = address + SPI_WRITE_CMD,
	      .length    = 4 * 8,
		  .tx_data = {value},
	assert(err==ESP_OK);
	err = spi_device_polling_transmit(m_stepper_cfg[channel].hspi, &t);
	if (err != ESP_OK ) printf("SPI WRITE ERROR (%d)\n", address);
BinaryPoet
Re: ESP-IDF 32bit register SPI read/write
Postby BinaryPoet » Tue May 21, 2024 11:49 am
Finally I get the SPI working by setting the address bits to 8:
spi_device_interface_config_t devcfg;
devcfg.clock_speed_hz = 10*1000*1000;           //Clock out at 10 MHz
devcfg.mode = 0;                                //SPI mode 0
devcfg.spics_io_num = (stepperAZ_AR == stepper ) ? PIN_NUM_CS1 : PIN_NUM_CS2;//CS pin
devcfg.queue_size = 8; 	//We want to be able to queue 5 transactions at a time
devcfg.command_bits = 0;
devcfg.address_bits = 8;
and with the following read/write functions:
		 esp_err_t err;
		 spi_transaction_t spitr;
		 memset(&spitr, 0, sizeof(spi_transaction_t));
		spitr.flags = 0;
		spitr.length = (8*4);
		spitr.rxlength = (8*4);
		spitr.addr = address;
		spitr.tx_buffer = &TxBuff;
		spitr.rx_buffer = &RxBuff;
		err = spi_device_polling_transmit(m_stepper_cfg[channel].hspi, &spitr);
		uint32_t res = SPI_SWAP_DATA_RX(RxBuff, 32);
		return(res);
	return -1;
	esp_err_t err;
	TxBuff = SPI_SWAP_DATA_RX(value, 32);
	RxBuff = 0;
	spitr.flags = 0;
	spitr.rxlength = 0;
	spitr.addr = address | SPI_WRITE_CMD;
The double read is related to the particular read mechanism of the device.
Users browsing this forum: Google [Bot] and 62 guests
