hello : )
I am using the ESP32-D0WB-V3 controller for my ESP32 project
Here I am interfacing the camera (capturing and storing the image into the SD card) along with this I need to use Bluetooth Serial communication.
complied output:
Sketch uses 1206833 bytes (92%) of program storage space. Maximum is 1310720 bytes.
Global variables use 44428 bytes (13%) of dynamic memory, leaving 283252 bytes for local variables. Maximum is 327680 bytes.
esp32 details:
Chip is ESP32-D0WD-V3 (revision v3.1)
Crystal is 40MHz
The problem is while capturing the camera image I am getting the error :
E (22154) cam_hal: cam_dma_config(316): DMA buffer 32768 Byte malloc failed, the current largest free block:16372 Byte
E (22155) cam_hal: cam_config(384): cam_dma_config failed
E (22159) camera: Camera config failed with error 0xffffffff
this error only happens when I integrate both Bluetooth and camera, individually both are working!
Please let me know how this issue can be resolved!!!!
ESP32-D0WB-V3 RAM getting filled while using both Bluetooth and camera
Users browsing this forum: Bing [Bot], ESP_Sprite, Google [Bot] and 73 guests
