WPA2-Enterprise using EAP-TLS? (no password.)
tpbedford
Postby tpbedford » Thu Mar 21, 2024 4:43 am
Have opened a ticket https://github.com/espressif/esp-idf/issues/13429 but thought the community might have some ideas. I'm trying to connect to an enterprise wifi (WPA2 Enterprise using EAP-TLS) but the enterprise AP reports that the ESP is requesting PEAP. But, I'm not specifying a username/password so the ESP shouldn't be trying PEAP.
Any tricks to work with WPA2-Enterprise EAP-TLS? It's not even reaching TLS negotiation because it's failing in negotiating the auth type (The AP supports only EAP-TLS, so it rejects PEAP)
    // this is from example/wifi-enterprise when configured for EAP-TLS (as opposed to TTLS or PEAP, which use username/password)
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_eap_client_set_identity((uint8_t *)EXAMPLE_EAP_ID, strlen(EXAMPLE_EAP_ID)) );
    ESP_ERROR_CHECK(esp_eap_client_set_ca_cert(ca_pem_start, ca_pem_bytes) );
    ESP_ERROR_CHECK(esp_eap_client_set_certificate_and_key(client_crt_start, client_crt_bytes,
                                      client_key_start, client_key_bytes, NULL, 0) );
    ESP_ERROR_CHECK(esp_wifi_sta_enterprise_enable());
    ESP_ERROR_CHECK(esp_wifi_start());
I'm not setting up the credentials, yet the Cisco AP event logs show:
Event: 5400 Authentication failed
Failure Reason: 12851 Received unexpected EAP NAK message. Client rejected the conversation
Resolution: Verify that the client's supplicant does not have any known compatibility issues and that it is properly configured.
Root cause: ISE expects for regular conversation continuation but client sent outer EAP method NAK message. It means that client rejected conversation for some reason that is unknown to ISE. Known issue: CSSC 5.1.1.10 sends outer EAP method NAK during EAP-FAST/EAP-GTC conversation to reject the conversation according to user's input.
Username: <my ESP32's identity here>
and the Cisco logs show the ESP is requesting PEAP (line 12301):
[1:49 pm] Joseph
11001 Received RADIUS Access-Request
11017 RADIUS created a new session
15049 Evaluating Policy Group
15008 Evaluating Service Selection Policy
15048 Queried PIP - DEVICE.Wired Dot1x
15048 Queried PIP - Radius.User-Name
15048 Queried PIP - Normalised Radius.RadiusFlowType
15048 Queried PIP - Cisco.cisco-av-pair
15048 Queried PIP - Radius.Called-Station-ID
15048 Queried PIP - DEVICE.Location
11507 Extracted EAP-Response/Identity
12500 Prepared EAP-Request proposing EAP-TLS with challenge
12625 Valid EAP-Key-Name attribute received
11006 Returned RADIUS Access-Challenge
11018 RADIUS is re-using an existing session
12301 Extracted EAP-Response/NAK requesting to use PEAP instead
12300 Prepared EAP-Request proposing PEAP with challenge
11504 Prepared EAP-Failure
11003 Returned RADIUS Access-Reject
[1:50 pm] Joseph
I can see your device is proposing PEAP on line12301
[1:50 pm] Joseph
That means it is doing username and password
tpbedford
Re: WPA2-Enterprise using EAP-TLS? (no password.)
Postby tpbedford » Tue Mar 26, 2024 9:56 pm
For anyone finding this refer the ticket but:
a) certs were using an encryption that was unsupported by mbedtls
b) the "len" arg given to esp_eap_client_set_certificate_and_key() unintuitively needs to be strlen(cert)+1
c) the esp_eap_client_set_certificate_and_key() doesn't parse the cert, so always returns ESP_OK even if the cert can't be parsed - the actual parsing is done in the background by the wifi task and this isn't communicated to the user unless additional WPA Supplicant debug log output is enabled in sdkconfig.
Users browsing this forum: No registered users and 125 guests
