We have released ESP-IDF VSCode extension 1.7.1, please check more details here.
Features and enhancements
- Add ESP-HOME-KIT framework
Bug Fixes
- Fix SDK Configuration editor info button
- Update docker container documentation
- Add openOCD troubleshooting link in error output
- Fix jtag pre post flash task
- Remove openOCD error messages from notifications
- Remove workspace folder selection from serial port selection
ESP-IDF VSCode Extension v1.7.1 Released
Re: ESP-IDF VSCode Extension v1.7.1 Released
Amazing! Thanks for continually improving this extension!
I've been using it for a while.
One comment - build clean is your friend if you do a lot of different projects at the same time.
Source Format
Apologies if I have double posted this.
I can see lots of improvements in the Eclipse IDE V3.0.0 however I can not change the C Code Formatter off default.
I use a custom format (like GNU) but even though I select it the Source -> Format always seem to use K&R Built in.
I can not even select other built in formatters or use "Project specific" format.
What do I need to do to change the code formatter?
Thank you
Thank you
Users browsing this forum: No registered users and 15 guests
