No such file or directory.
Vineethad
Postby Vineethad » Thu Mar 07, 2024 4:34 am
I am working with an Esp32c6 module and the tool is Espressif IDE(v5.1.2). I am created a new project and added the components when I included the spi.h into main file. while compiling the project I am getting error like "No such file or directory".
How to solve this problem ?.
Thanks & Regards,
D. Vineetha.
Screenshot 2024-03-07 095700.png (104.13 KiB) Viewed 2707 times
liaifat85
Re: No such file or directory.
Postby liaifat85 » Sun Mar 10, 2024 12:08 pm
Ensure that the "spi.h" file is located in the correct directory within your project structure. If it's not, move it to the appropriate directory.
Vineethad
Postby Vineethad » Mon Mar 11, 2024 4:09 am
Thanks for the response,
Actually I am following the below process to create a new component as right click on the project->new->espressif ide component.
Please let me know what is the mistake in creating of a new component.
Vineethad
Postby Vineethad » Mon Mar 11, 2024 4:11 am
Screenshot 2024-03-11 093436.png (22.2 KiB) Viewed 2565 times
Screenshot 2024-03-11 094027.png (49.73 KiB) Viewed 2565 times
chegewara
Postby chegewara » Mon Mar 11, 2024 5:07 am
Im not sure if this is the case with IDE, but with command line idf.py when you add new component, or even just new .c, .cpp file you have to make
idf.py fullclean
Its because cmake does not search for new files and new components, just rebuilding if files changes are detected.
Users browsing this forum: No registered users and 67 guests
