SD.Open() causes crashing with esp32
The default library for reading / writing to SD seems to not work correctly with esp32. All the functions work well in Setup() but if you try to read or write to a file in loop() then it causes a crash with this error
10:22:03.495 -> Listing directory: /
10:22:03.495 -> DIR : System Volume Information
10:22:03.495 -> FILE: test.txt SIZE: 1048576
10:22:03.495 -> FILE: foo.txt SIZE: 13
10:22:03.495 -> FILE: blue-flower.bmp SIZE: 153666
10:22:03.538 -> FILE: Slime01_32x32.bmp SIZE: 2114
10:22:03.538 -> FILE: Slime02.bmp SIZE: 2114
10:22:03.538 -> FILE: Slime03_32x34.bmp SIZE: 2242
10:22:03.538 -> FILE: Spaceship.bmp SIZE: 2650
10:22:03.538 -> FILE: bruh.txt SIZE: 12
10:22:03.538 -> FILE: gameastroid.bmp SIZE: 4674
10:22:04.549 -> Reading File
10:22:04.549 -> Writing file: /hello.txt
10:22:04.549 ->
10:22:04.549 -> assert failed: xQueueSemaphoreTake queue.c:1545 (( pxQueue ))
10:22:04.549 ->
10:22:04.549 ->
10:22:04.549 -> Backtrace: 0x400835dd:0x3ffb1ae0 0x4008984d:0x3ffb1b00 0x4008e749:0x3ffb1b20 0x4008a5ad:0x3ffb1c50 0x400d4d6e:0x3ffb1c90 0x400d2541:0x3ffb1cc0 0x400e351a:0x3ffb1cf0 0x400e3819:0x3ffb1d10 0x400e57b3:0x3ffb1d50 0x400e6fd6:0x3ffb1fc0 0x400e092a:0x3ffb2130 0x400f0e28:0x3ffb2150 0x400d4876:0x3ffb2170 0x400d37be:0x3ffb2200 0x400d188b:0x3ffb2230 0x400d19c9:0x3ffb2270 0x400d80a9:0x3ffb2290
10:22:04.596 ->
10:22:04.596 ->
10:22:04.596 ->
10:22:04.596 ->
10:22:04.596 -> ELF file SHA256: d311bda49d21a55e
My guess is the default library might be using while loops which don't have delays for the watchdog task
10:22:04.549 ->
10:22:04.549 ->
10:22:04.549 ->
10:22:04.596 ->
10:22:04.596 ->
10:22:04.596 ->
10:22:04.596 ->
Re: SD.Open() causes crashing with esp32
The examples in the file system libraries are primarily there for unit testing, to verify that changes in the code have not impacted the behavior. Some pieces are quite generally useful (file listing). Some will need to be modified to use in live code.
Is there a question here? If you are conducting operations on multiple files at high priority, you should have a delay in between them to allow the system time to operate.
It doesnt work with delay or without. Just immediately causes crash Whenever its used in Loop(). Im only trying to read a file. But it crashes on all Reading or writing.
If you were to post a minimal example, we could help you.
This also produces same error. Also this doesnt happen with SdFat library. Just the ones from esp32 default libraries
#include "SD.h"
#include "SPI.h"
#define HSPI_MISO 12
#define HSPI_MOSI 13
#define HSPI_SCLK 14
#define HSPI_SS 27
SPIClass * hspi = NULL;
static const uint32_t hspiClk = 16000000; // 16 MHz The sd card im using only supports 8 or 16 Mhz spi.
bool StorageMounted = false;
void setup(){
Serial.begin(115200);
hspi = new SPIClass(HSPI);
SPIClass mSPI = *hspi;
pinMode(HSPI_SS, OUTPUT);
//digitalWrite(HSPI_SS, HIGH);
hspi->begin(HSPI_SCLK,HSPI_MISO,HSPI_MOSI,HSPI_SS);
// hspi->beginTransaction(SPISettings(spiClk, MSBFIRST, SPI_MODE0));
bool SD_OK = SD.begin(HSPI_SS,mSPI,hspiClk,"/sd",10,false);
if(!SD_OK){
Serial.println("Card Mount Failed");
return;
else { StorageMounted = true ; Serial.println("Card Mounted. "); }
uint8_t cardType = SD.cardType();
if(cardType == CARD_NONE){
Serial.println("No SD card attached");
return;
Serial.print("SD Card Type: ");
if(cardType == CARD_MMC){
Serial.println("MMC");
} else if(cardType == CARD_SD){
Serial.println("SDSC");
} else if(cardType == CARD_SDHC){
Serial.println("SDHC");
} else {
Serial.println("UNKNOWN");
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("SD Card Size: %lluMB\n", cardSize);
listDir(SD, "/", 0);
void listDir(fs::FS &fs, const char * dirname, uint8_t levels){
Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if(!root){
Serial.println("Failed to open directory");
return;
if(!root.isDirectory()){
Serial.println("Not a directory");
return;
File file = root.openNextFile();
while(file){
if(file.isDirectory()){
Serial.print(" DIR : ");
Serial.println(file.name());
if(levels){
listDir(fs, file.path(), levels -1);
} else {
Serial.print(" FILE: ");
Serial.print(file.name());
Serial.print(" SIZE: ");
Serial.println(file.size());
void readFile(fs::FS &fs, const char * path, char* FileBuffer, uint32_t FileSize){
Serial.printf("Reading file: %s\n", path);
File file = fs.open(path);
if(!file){
Serial.println("Failed to open file for reading");
return;
Serial.print("Read from file: ");
while(file.available()){
file.readBytes(FileBuffer, FileSize);
file.close();
bool disableREAD =false;
char* DBuffer = (char*)malloc(1024);
void loop(){
if(StorageMounted && !disableREAD)
readFile(SD, "/test.txt",DBuffer,8);
Serial.println("Done Reading");
disableREAD =true;
bool SD_OK = SD.begin(HSPI_SS,*(hspi));
I have did a number of project using the Arduino Sd and greiman/SdFat
That supports >32GB sd cards and test on all ESP ( exspet the new ones H2/C6 )
You can have a look at the total projects ( Wifi manager, OTA updates, NTP time , and SD card , FTP Server)
https://github.com/EmileSpecialProducts ... sk-driveEx
https://github.com/EmileSpecialProducts ... disk-drive
https://github.com/EmileSpecialProducts/FTP-WebServer
The FTP-Webserver is not yet supportin >32GB
Btw this is written in arduino ide
@lbernstone the problem wasn't the spi code. It is the default esp32 SD library. Also the simulation isn't perfect so it will pass this code that doesn't work on real hardware.
@Emile_esp your code doesn't exactly read files from loop. the SD can read /write to files but only in the Setup() function. Put it on Loop and it fails and causes crashing.
You are welcome to open an issue in the repo. They will want example code and a decoded backtrace from the error.
I've just run into this problem too. The solution is to move the definition of the SPI object into global scope rather than have it as a local object which goes out of scope after the setup function has finished. The example in the SD library is also wrong and has been copied to other SD examples as well.
Users browsing this forum: No registered users and 51 guests
