changing wifi password
Jimis1
Postby Jimis1 » Thu Feb 29, 2024 3:00 pm
I have set up the https_ota_example. The password is set up through menuconfig but is there a way to change the password from inside the code calling a function or something. I couldn't find anything on the documentation
MicroController
Re: changing wifi password
Postby MicroController » Thu Feb 29, 2024 3:47 pm
Documentation: https://docs.espressif.com/projects/esp ... i_config_t
The relevant code from the examples is here/here.
Jimis1
Postby Jimis1 » Fri Mar 01, 2024 7:16 am
Like I said I didn't find how to change the password in the documentation. I don't see the library providing a function for that. Changing the library is not very wise since other updates might change it back
ves011
Postby ves011 » Fri Mar 01, 2024 6:27 pm
You don't need to change anything. @MicroController pointed you to the right places.
Here is a small example
bool wifi_join(const char *ssid, const char *pass, int timeout_ms)
	int bits = 0;
	if(isConnected())
	    wifi_disconnect(1, NULL);
    	wifi_config_t wifi_config = { 0 };
    	strlcpy((char *) wifi_config.sta.ssid, ssid, sizeof(wifi_config.sta.ssid));
    	if (pass)
        	strlcpy((char *) wifi_config.sta.password, pass, sizeof(wifi_config.sta.password));
    	ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
	esp_wifi_connect();
    	bits = xEventGroupWaitBits(wifi_event_group, CONNECTED_BIT,
                                   pdFALSE, pdTRUE, timeout_ms / portTICK_PERIOD_MS);
    	return (bits & CONNECTED_BIT) != 0;
Jimis1
Postby Jimis1 » Sat Mar 02, 2024 6:50 am
Thanks a lot ! That's what I was looking for!
I searched for that function and found it here :
esp-idf\examples\system\console\advanced\components\cmd_wifi\cmd_wifi.c
I will test it
Users browsing this forum: Baldhead and 96 guests
