help for rebuilding sketch (esp8266) for esp32 ?
feredy2011
Postby feredy2011 » Mon Aug 14, 2017 8:55 pm
hi friends.
thank you for esp32 . this is a interesting module.
i am beginner in esp32 so please help me to rebuilding my sketch with esp32. thank you
this is my sketch that i use for esp8266, can you change this for esp32 ?
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <Bounce2.h>
IPAddress ip(192, 168, 1, 241);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress DNS(192, 168, 1, 1);
const char* ssid = "XXX";
const char* password = "XXXX";
const int buttonPinA = D5;
const int relayPinA = D1;
Bounce debouncerA = Bounce();
int trigger = 0;
int oldValueA;
WiFiClient client;
WiFiServer server(80);
void setup() {
  pinMode(buttonPinA, INPUT_PULLUP);
  debouncerA.attach(buttonPinA);
  debouncerA.interval(50);
  pinMode(relayPinA, OUTPUT);
  digitalWrite(relayPinA, HIGH);
  Serial.begin(115200);
  delay(10);
  // Connect to WiFi network
  Serial.println();
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.config(ip, gateway, subnet, DNS);//**********************
  delay(100);//**********************************
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  /* while (WiFi.status() != WL_CONNECTED) {
     delay(500);
     Serial.print(".");
  /*  if (WiFi.status() != WL_CONNECTED) {
      Serial.println("Error in connection");
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.print("Use this URL : ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  debouncerA.update();
  oldValueA = debouncerA.read();
void loop() {
    if (trigger == 0) {
      if (client.connect("192.168.1.201", 8080)) {
        client.print("GET /json.htm?type=command&param=udevice&idx=55&nvalue=0");
        client.println(" HTTP/1.1");
        client.print("Host: ");
        client.print("192.168.1.201");
        client.print(":");
        client.println(8080);
        client.println();
        client.stop();
        client.print("GET /json.htm?type=command&param=addlogmessage&message=OFF");
        client.print(":");
        client.println();
        client.stop();
      trigger = 1;
    int valueA = debouncerA.read();
    if (valueA != oldValueA) {
      int state = digitalRead(relayPinA);
      digitalWrite(relayPinA, !state);
      if ( state == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( state == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=55&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print("GET /json.htm?type=command&param=addlogmessage&message=ON");
          client.print(":");
          client.println();
          client.stop();
    oldValueA = valueA;
    delay(50);
    WiFiClient client = server.available();
    if (!client) {
      return;
    Serial.println("new client");
    while (!client.available()) {
      delay(1);
    String request = client.readStringUntil('\r');
    Serial.println(request);
    client.flush();
    if (request.indexOf("/relayon") != -1) {
      digitalWrite(relayPinA, LOW);
    if (request.indexOf("/relayoff") != -1) {
    client.println("HTTP/1.1 200 OK");
    client.println("Content-Type: text/html");
    client.println(""); //  do not forget this one
    client.println("<!DOCTYPE HTML>");
    client.println("<html>");
please help me to upload this code to esp32 .thank you
gdsports
Re: help for rebuilding sketch (esp8266) for esp32 ?
Postby gdsports » Wed Aug 16, 2017 5:50 am
I suggest looking at the examples to see what has changed.
One big change is the include file names have changed. Try changing ESP8266WiFi.h to WiFi.h and ESP8266mDNS.h to ESPmDNS.h.
feredy2011
Postby feredy2011 » Wed Aug 16, 2017 3:14 pm
gdsports wrote:I suggest looking at the examples to see what has changed.
thank you friend.for answer. where is examples?
i change this and code was compile seccess and in serial monitor i see connect to network but there is not in mynetwork
feredy2011
Postby feredy2011 » Thu Aug 17, 2017 6:01 am
thank you for answer. i change my code and compile is done, but after upload dont work well. some relay will on in startup(i set all relay to 0)but some relay turn on auto. also after connect to wifi,some key dont work,some code send with a delay....
this is my code for 10 channel relay, do you think this code have a problem ?please help me thank you
#include "WiFi.h"
/*IPAddress ip(192, 168, 1, 90);
IPAddress DNS(192, 168, 1, 1);*/
const char* ssid = "Reza";
const char* password = "rayan1369";
const int buttonPinA = 22;
const int buttonPinB = 23;
const int buttonPinC = 19;
const int buttonPinD = 4;
const int buttonPinE = 26;
const int buttonPinF = 25;
const int buttonPinG = 14;
const int buttonPinH = 27;
const int buttonPinI = 33;
const int buttonPinJ = 32;
const int relayPinA = 0;
const int relayPinB = 12;
const int relayPinC = 15;
const int relayPinD = 21;
const int relayPinE = 2;
const int relayPinF = 13;
const int relayPinG = 18;
const int relayPinH = 5;
const int relayPinI = 17;
const int relayPinJ = 16;
Bounce debouncerB = Bounce();
Bounce debouncerC = Bounce();
Bounce debouncerD = Bounce();
Bounce debouncerE = Bounce();
Bounce debouncerF = Bounce();
Bounce debouncerG = Bounce();
Bounce debouncerH = Bounce();
Bounce debouncerI = Bounce();
Bounce debouncerJ = Bounce();
int trigger = 0;
int oldValueA;
int oldValueB;
int oldValueC;
int oldValueD;
int oldValueE;
int oldValueF;
int oldValueG;
int oldValueH;
int oldValueI;
int oldValueJ;
WiFiClient client;
void setup() {
  debouncerA.interval(100);
  pinMode(buttonPinB, INPUT_PULLUP);
  debouncerB.attach(buttonPinB);
  debouncerB.interval(100);
  pinMode(buttonPinC, INPUT_PULLUP);
  debouncerC.attach(buttonPinC);
  debouncerC.interval(100);
  pinMode(buttonPinD, INPUT_PULLUP);
  debouncerD.attach(buttonPinD);
  debouncerD.interval(100);
  pinMode(buttonPinE, INPUT_PULLUP);
  debouncerE.attach(buttonPinE);
  debouncerE.interval(100);
  pinMode(buttonPinF, INPUT_PULLUP);
  debouncerF.attach(buttonPinF);
  debouncerF.interval(100);
  pinMode(buttonPinG, INPUT_PULLUP);
  debouncerG.attach(buttonPinG);
  debouncerG.interval(100);
  pinMode(buttonPinH, INPUT_PULLUP);
  debouncerH.attach(buttonPinH);
  debouncerH.interval(100);
  pinMode(buttonPinI, INPUT_PULLUP);
  debouncerI.attach(buttonPinI);
  debouncerI.interval(100);
  pinMode(buttonPinJ, INPUT_PULLUP);
  debouncerJ.attach(buttonPinJ);
  debouncerJ.interval(100);
  pinMode(relayPinB, OUTPUT);
  digitalWrite(relayPinB, HIGH);
  pinMode(relayPinC, OUTPUT);
  digitalWrite(relayPinC, HIGH);
  pinMode(relayPinD, OUTPUT);
  digitalWrite(relayPinD, HIGH);
  pinMode(relayPinE, OUTPUT);
  digitalWrite(relayPinE, HIGH);
  pinMode(relayPinF, OUTPUT);
  digitalWrite(relayPinF, HIGH);
  pinMode(relayPinG, OUTPUT);
  digitalWrite(relayPinG, HIGH);
  pinMode(relayPinH, OUTPUT);
  digitalWrite(relayPinH, HIGH);
  pinMode(relayPinI, OUTPUT);
  digitalWrite(relayPinI, HIGH);
  pinMode(relayPinJ, OUTPUT);
  digitalWrite(relayPinJ, HIGH);
  delay(10);
  Serial.println();
  Serial.println();
 /* WiFi.config(ip, gateway, subnet, DNS);//**********************
  delay(100);//**********************************/
    for (int i = 0; i <= 20; i++) {
      delay(500);
      Serial.print(".");
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("");
  // Start the server
  server.begin();
  debouncerB.update();
  oldValueB = debouncerB.read();
  debouncerC.update();
  oldValueC = debouncerC.read();
  debouncerD.update();
  oldValueD = debouncerD.read();
  debouncerE.update();
  oldValueE = debouncerE.read();
  debouncerF.update();
  oldValueF = debouncerF.read();
  debouncerG.update();
  oldValueG = debouncerG.read();
  debouncerH.update();
  oldValueH = debouncerH.read();
  debouncerI.update();
  oldValueI = debouncerI.read();
  debouncerJ.update();
  oldValueJ = debouncerJ.read();
void loop() {
      Serial.println();
      Serial.println();
      //WiFi.config(ip, gateway, subnet, DNS);
      delay(100);
      Serial.println("");
      delay(100);
      // Start the server
      server.begin();
      delay(1000);
    if (trigger == 0) {
        client.print("GET /json.htm?type=command&param=udevice&idx=62&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print("GET /json.htm?type=command&param=udevice&idx=63&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print("GET /json.htm?type=command&param=udevice&idx=64&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print("GET /json.htm?type=command&param=udevice&idx=65&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print("GET /json.htm?type=command&param=udevice&idx=66&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print("GET /json.htm?type=command&param=udevice&idx=67&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print("GET /json.htm?type=command&param=udevice&idx=68&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print("GET /json.htm?type=command&param=udevice&idx=69&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print("GET /json.htm?type=command&param=udevice&idx=70&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print("GET /json.htm?type=command&param=udevice&idx=71&nvalue=0");
        client.print(":");
        client.println();
        client.stop();
      delay(20);
        client.print(":");
        client.println();
        client.stop();
      trigger = 1;
      int stateA = digitalRead(relayPinA);
      digitalWrite(relayPinA, !stateA);
      if ( stateA == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateA == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=62&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueA = valueA;
    int valueB = debouncerB.read();
    if (valueB != oldValueB) {
      int stateB = digitalRead(relayPinB);
      digitalWrite(relayPinB, !stateB);
      if ( stateB == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateB == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=63&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueB = valueB;
    int valueC = debouncerC.read();
    if (valueC != oldValueC) {
      int stateC = digitalRead(relayPinC);
      digitalWrite(relayPinC, !stateC);
      if ( stateC == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateC == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=64&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueC = valueC;
    int valueD = debouncerD.read();
    if (valueD != oldValueD) {
      int stateD = digitalRead(relayPinD);
      digitalWrite(relayPinD, !stateD);
      if ( stateD == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateD == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=65&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueD = valueD;
    int valueE = debouncerE.read();
    if (valueE != oldValueE) {
      int stateE = digitalRead(relayPinE);
      digitalWrite(relayPinE, !stateE);
      if ( stateE == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateE == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=66&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueE = valueE;
    int valueF = debouncerF.read();
    if (valueF != oldValueF) {
      int stateF = digitalRead(relayPinF);
      digitalWrite(relayPinF, !stateF);
      if ( stateF == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateF == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=67&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueF = valueF;
    int valueG = debouncerG.read();
    if (valueG != oldValueG) {
      int stateG = digitalRead(relayPinG);
      digitalWrite(relayPinG, !stateG);
      if ( stateG == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateG == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=68&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueG = valueG;
    int valueH = debouncerH.read();
    if (valueH != oldValueH) {
      int stateH = digitalRead(relayPinH);
      digitalWrite(relayPinH, !stateH);
      if ( stateH == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateH == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=69&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueH = valueH;
    int valueI = debouncerI.read();
    if (valueI != oldValueI) {
      int stateI = digitalRead(relayPinI);
      digitalWrite(relayPinI, !stateI);
      if ( stateI == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateI == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=70&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueI = valueI;
    int valueJ = debouncerJ.read();
    if (valueJ != oldValueJ) {
      int stateJ = digitalRead(relayPinJ);
      digitalWrite(relayPinJ, !stateJ);
      if ( stateJ == 0) {
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
      if ( stateJ == 1) {
          client.print("GET /json.htm?type=command&param=udevice&idx=71&nvalue=1");
          client.print(":");
          client.println();
          client.stop();
          client.print(":");
          client.println();
          client.stop();
    oldValueJ = valueJ;
    if (!client) {
      return;
      delay(1);
    client.flush();
    if (request.indexOf("/relay1on") != -1) {
    if (request.indexOf("/relay1off") != -1) {
    if (request.indexOf("/relay2on") != -1) {
      digitalWrite(relayPinB, LOW);
    if (request.indexOf("/relay2off") != -1) {
    if (request.indexOf("/relay3on") != -1) {
      digitalWrite(relayPinC, LOW);
    if (request.indexOf("/relay3off") != -1) {
    if (request.indexOf("/relay4on") != -1) {
      digitalWrite(relayPinD, LOW);
    if (request.indexOf("/relay4off") != -1) {
    if (request.indexOf("/relay5on") != -1) {
      digitalWrite(relayPinE, LOW);
    if (request.indexOf("/relay5off") != -1) {
    if (request.indexOf("/relay6on") != -1) {
      digitalWrite(relayPinF, LOW);
    if (request.indexOf("/relay6off") != -1) {
    if (request.indexOf("/relay7on") != -1) {
      digitalWrite(relayPinG, LOW);
    if (request.indexOf("/relay7off") != -1) {
    if (request.indexOf("/relay8on") != -1) {
      digitalWrite(relayPinH, LOW);
    if (request.indexOf("/relay8off") != -1) {
    if (request.indexOf("/relay9on") != -1) {
      digitalWrite(relayPinI, LOW);
    if (request.indexOf("/relay9off") != -1) {
    if (request.indexOf("/relay10on") != -1) {
      digitalWrite(relayPinJ, LOW);
    if (request.indexOf("/relay10off") != -1) {
Users browsing this forum: No registered users and 51 guests
