Unable to toggle esp32 c6 GPIO_NUM_4
sauravkumal
Postby sauravkumal » Wed Feb 21, 2024 8:40 am
Hi, I am not sure why i am unable to toggle esp32 c6 GPIO_4. I am able to toggle GPIO_5. Same code works for esp32.
But for GPIO_4 its always low. Does this pin require special configuration? I looked throughout the documentation and didn't find such case.
  1. #include <stdio.h>
  2.
  3. #include "esp_log.h"
  4.
  5. #include "lvgl.h"
  6. #include "freertos/FreeRTOS.h"
  7. #include "freertos/task.h"
  8. #include "driver/gpio.h"
  9.
  10. static const char *TAG = "WATCH";
  11. static bool state;
  12.
  13. void app_main(void)
  14. {
  15.     ESP_LOGD(TAG, "Start Main");
  16.
  17.     gpio_set_direction(GPIO_NUM_4, GPIO_MODE_OUTPUT);
  18.     gpio_set_level(GPIO_NUM_4, 1);
  19.     state = false;
  20.
  21.     while (true)
  22.     {
  23.         if (state == true)
  24.         {
  25.             gpio_set_level(GPIO_NUM_4, 0);
  26.             state = false;
  27.             ESP_LOGD(TAG, "Motor off");
  28.         }
  29.         else
  30.         {
  31.             state = true;
  32.             gpio_set_level(GPIO_NUM_4, 1);
  33.             ESP_LOGD(TAG, "Motor on");
  34.         }
  35.
  36.         vTaskDelay(pdMS_TO_TICKS(1000));
  37.     }
  38. }
JoeSensoric
Re: Unable to toggle esp32 c6 GPIO_NUM_4
Postby JoeSensoric » Mon Feb 26, 2024 9:41 pm
Which board are you using? Do you have a schematic?
Perhaps there is something connected to GPIO4 onboard.
sauravkumal
Postby sauravkumal » Fri May 10, 2024 9:59 pm
I am now using esp32 c6 wroom-1 dev board without connecting anything. Still not working.
JoeSensoric
Postby JoeSensoric » Sun May 12, 2024 8:48 am
In the datasheet GPIO4 and 5 (and others) are highlighted with reference to chapter "2.3.4 Restrictions for GPIOs and LP GPIOs".
Both GPIOs are used for SPI and are "input enabled" at boot time and after.
The non-highlighted GPIO or LP GPIO pins are recommended for use first.
This should not interfere with your program...
skwidder
Postby skwidder » Mon Jun 17, 2024 4:49 pm
I'm having this same issue as well as being unable to set the Pin as a UART. Did anyone find a solution to this issue?
fasani
Contact:
Postby fasani » Sat Nov 09, 2024 10:26 am
I also hit this issue. In my case both C6 GPIO_NUM_4 & 5 are low or in a strange "floating state" but I cannot toggle them high...
OWN board with QFN40: https://github.com/martinberlin/H-C6-ul ... st.1.0.pdf
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
Users browsing this forum: Google [Bot], MicroController and 59 guests
