I am programming ESP32-WROOM-32D with Arduino IDE. In this website (https://docs.espressif.com/projects/esp ... %2D%2027).), it says that the ADC2 module can only be used when WiFi driver is not activated.
In my case, I try to use the BluetoothSerial library (the commands start with SerialBT) together with the ADC2 module, and I found that ADC2 GPIOs seem to be not working. Therefore, I would like to ask if the BluetoothSerial library is also using the WiFi driver which leads to the problem.
I also read from this website (https://docs.espressif.com/projects/esp ... hannel_tPi) that the adc_oneshot_read() is thread safe and can be used with WiFi. Is my understanding correct? It would be great if anyone can provide some experiences.
Thank you very much for any information.
ESP32: can BluetoothSerial be used with ADC2 module?
Re: ESP32: can BluetoothSerial be used with ADC2 module?
I think you'll find your answer here: https://esp32.com/viewtopic.php?t=20057
Short answer is no. The radio uses the ADC2 exclusively.
Thank you very much for pointing me to the post.liaifat85 wrote: ↑Fri Jan 12, 2024 8:20 amI think you'll find your answer here: https://esp32.com/viewtopic.php?t=20057
Thank you for your information. By using the word "radio," are you referring to both Bluetooth and WiFi?lbernstone wrote: ↑Fri Jan 12, 2024 2:12 pmShort answer is no. The radio uses the ADC2 exclusively.
And do you have any idea if adc_oneshot_read() will work for ADC2 when Bluetooth is on?
yes
no
tl;dr Don't do this. Use ADC1 for analog reads.
no
Thank you very much for your help.
Users browsing this forum: No registered users and 36 guests
