Issue with ESP-NOW functionality when connecting to WebSocket server in Node.js
agoktugaydin
Postby agoktugaydin » Wed Jan 10, 2024 4:32 pm
Hello everyone,
I'm currently working on a project where I have a server written in Node.js that utilizes WebSocket functionality. However, when I connect my ESP32 device (running the Arduino code provided below) to this server, the ESP-NOW functionality stops working.
  1. #include <Arduino.h>
  2. #include <Wire.h>
  3. #include <WiFi.h>
  4. #include <esp_now.h>
  5. #include <WebSocketsClient.h>
  6. #include <ArduinoJson.h>
  7. #include <Adafruit_GFX.h>
  8. #include <Adafruit_SSD1306.h>
  9. #include <config.h>
  10.
  11. IPAddress webSocketServer(WEBSOCKET_SERVER_IP1, WEBSOCKET_SERVER_IP2, WEBSOCKET_SERVER_IP3, WEBSOCKET_SERVER_IP4);
  12. int webSocketPort = WEBSOCKET_SERVER_PORT;
  13. const char * ssid = WIFI_SSID;
  14. const char * password = WIFI_PASSWORD;
  15.
  16. WebSocketsClient wsClient;
  17.
  18. const int analogIn = A0;
  19. int rawValue = 0;
  20. double voltage = 0;
  21. double rawSum = 0;
  22. int limit = 2000;
  23. int percentage = 0;
  24.
  25. #define OLED_RESET 4
  26. Adafruit_SSD1306 display(OLED_RESET);
  27.
  28. typedef struct struct_message {
  29.   int id;
  30.   int x;
  31.   int y;
  32. }
  33. struct_message;
  34.
  35. struct_message myData;
  36. struct_message board1;
  37. struct_message boardsStruct[1] = {
  38.   board1
  39. };
  40.
  41. void OnDataRecv(const uint8_t * mac_addr,
  42.   const uint8_t * incomingData, int len) {
  43.   char macStr[18];
  44.   Serial.print("Packet received from: ");
  45.   snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
  46.     mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
  47.   Serial.println(macStr);
  48.   memcpy( & myData, incomingData, sizeof(myData));
  49.   Serial.printf("Board ID %u: %u bytes\n", myData.id, len);
  50.   boardsStruct[myData.id - 1].x = myData.x;
  51.   boardsStruct[myData.id - 1].y = myData.y;
  52.   Serial.printf("x value: %d \n", boardsStruct[myData.id - 1].x);
  53.   Serial.printf("y value: %d \n", boardsStruct[myData.id - 1].y);
  54.   Serial.println("Data received from ESP-NOW");
  55.
  56. }
  57.
  58. void displayValues() {
  59.   rawSum = analogRead(analogIn);
  60.
  61.   for (int i = 0; i < 500; i++) {
  62.     rawSum += analogRead(analogIn);
  63.   }
  64.
  65.   rawValue = rawSum / 500;
  66.   voltage = (rawValue / 4096.0) * 3300;
  67.   percentage = map(rawValue, 1400, 4096, 0, 100);
  68.
  69.   display.setTextColor(WHITE);
  70.   display.setTextSize(1);
  71.   display.setCursor(0, 0);
  72.
  73.   if (rawValue < limit) {
  74.     digitalWrite(LED_BUILTIN, LOW);
  75.     digitalWrite(18, LOW);
  76.     display.print("NORMAL");
  77.     display.setCursor(0, 10);
  78.     display.print("raw value:");
  79.     display.print(rawValue);
  80.     display.print("\n");
  81.     display.print("received value:");
  82.     display.print(boardsStruct[0].x);
  83.     display.print("\n");
  84.     display.print("Percentage: ");
  85.     display.print(percentage);
  86.     display.print("%");
  87.   } else {
  88.     digitalWrite(LED_BUILTIN, HIGH);
  89.     digitalWrite(18, HIGH);
  90.     display.print("LEAK");
  91.     display.setCursor(0, 10);
  92.     display.print("raw value:");
  93.     display.print(rawValue);
  94.     display.print("\n");
  95.     display.print("received value:");
  96.     display.print(boardsStruct[0].x);
  97.     display.print("\n");
  98.     display.print("Percentage: ");
  99.     display.print(percentage);
  100.     display.print("%");
  101.
  102.   }
  103.
  104.   display.display();
  105.   delay(300);
  106.   display.clearDisplay();
  107. }
  108.
  109. void sendData() {
  110.
  111.   StaticJsonDocument < 200 > jsonData;
  112.
  113.   jsonData["deviceId"] = "3bf76280-6ca9-4d83-9ffb-db112de00c24";
  114.   jsonData["gasIntensity"] = percentage;
  115.   jsonData["zone"] = "43C72";
  116.
  117.   String serializedData;
  118.   serializeJson(jsonData, serializedData);
  119.
  120.   wsClient.sendTXT(serializedData);
  121.   Serial.println(serializedData);
  122.
  123. }
  124.
  125. void wsEvent(WStype_t type, uint8_t * payload, size_t length) {
  126.   if (type == WStype_DISCONNECTED) {
  127.     Serial.println("Disconnected from WebSocket server.");
  128.   } else if (type == WStype_CONNECTED) {
  129.     Serial.println("Connected to WebSocket server.");
  130.   } else if (type == WStype_TEXT) {
  131.     Serial.println("Received data from WebSocket server:");
  132.     Serial.println((char * ) payload);
  133.   }
  134. }
  135.
  136. void setup() {
  137.   pinMode(LED_BUILTIN, OUTPUT);
  138.   pinMode(18, OUTPUT);
  139.
  140.   Wire.begin();
  141.   display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  142.
  143.   Serial.begin(115200);
  144.
  145.   WiFi.mode(WIFI_AP_STA);
  146.
  147.   WiFi.begin(ssid, password);
  148.   while (WiFi.status() != WL_CONNECTED) {
  149.     delay(1000);
  150.     Serial.println("Connecting to WiFi...");
  151.   }
  152.
  153.   if (esp_now_init() != ESP_OK) {
  154.     Serial.println("Error initializing ESP-NOW");
  155.     return;
  156.   }
  157.
  158.   esp_now_register_recv_cb(OnDataRecv);
  159.
  160.   delay(300);
  161.   WiFi.begin(ssid, password);
  162.
  163.   wsClient.begin(webSocketServer, webSocketPort);
  164.   wsClient.onEvent(wsEvent);
  165.   Serial.println("WebSocket client started...");
  166.
  167. }
  168.
  169. void loop() {
  170.   displayValues();
  171.   delay(300);
  172.   wsClient.loop();
  173.   static unsigned long lastSent = 0;
  174.   unsigned long now = millis();
  175.
  176.   if (wsClient.isConnected() && now - lastSent >= 2000) {
  177.     sendData();
  178.
  179.   }
Problem:
The ESP32 device is designed to communicate using ESP-NOW, which works perfectly when not connected to the WebSocket server.
Upon connecting to the WebSocket server using the WebSocketsClient library, the ESP-NOW functionality seems to cease, and no data is received through ESP-NOW.
Expected Behavior:
The ESP-NOW functionality should continue to work seamlessly even when the WebSocket connection is established.
Additional Information:
The WebSocket server is implemented in Node.js.
The WebSocket library used on the ESP32 side is WebSocketsClient
The ESP-NOW functionality is used for communication between multiple ESP32 devices.
Possible Causes:
The WebSocket library may be interfering with ESP-NOW operations.
Attempts to Resolve:
I have checked for any conflicts in network configurations.
I've tried adjusting the order of initialization for ESP-NOW and WebSocket.
I appreciate any insights or suggestions on how to troubleshoot and resolve this issue. If you need additional details, feel free to ask.
Thank you in advance!
Users browsing this forum: No registered users and 41 guests
