Hi All,
I have spent almost 2 weeks trying to get to the stage where I can compile and download hello_world, and am now getting "No pyvenv.cfg file" in both Eclipse IDE with Espressif IDF plugin and also in Espressif IDE. I have at least 4 copies of this file in the folder where python.exe resides for both the python installation and also the python virtual environment folder, and also in the parent folders for these 2 folders. but the system can't seem to find them. The following is a partial log of activity showing the error. :
Python being checked: C:\Users\User\.espressif\python_env\idf5.1_py3.12_env\Scripts\python.exe
No pyvenv.cfg file
CMake Error at D:/Espressif/esp-idf-v5.1.2/tools/cmake/build.cmake:366 (message):
See also "D:/Espressif/hello/build/CMakeFiles/CMakeOutput.log".
Failed to run Python dependency check. Python: python, Error: -106
D:/Espressif/esp-idf-v5.1.2/tools/cmake/build.cmake:498 (__build_check_python)
D:/Espressif/esp-idf-v5.1.2/tools/cmake/project.cmake:547 (idf_build_process)
CMakeLists.txt:6 (project)
On top of this I spent quite a while solving the issue of No espidf.constraints.v5.1.txt file. I found something online and copied it into a txt file and saved it to the appropriate folder and this seemed to get me one small step further. It's been a long hard struggle to get this far.
I can't seem to find any indormation online about the pyvenv.cfg file missing.
Any help would be appreciated.
Thanks in advance,
Bill
No pyvenv.cfg file
Re: No pyvenv.cfg file
You could try idf_tools.py install-python-env.
Thanks Microcontroller,
I executed this from a command shell :
C:\Users\User\.espressif>C:\Users\User\AppData\Local\Programs\Python\Python312\python.exe D:\Espressif\esp-idf-v5.1.2\tools\idf_tools.py install-python-env
ERROR: This script was called from a virtual environment, can not create a virtual environment again
Before I did this I ran the install tools from within Espressif IDE and it gave the same result.
Any more Ideas?
Bill
Any more Ideas?
Bill
- ESP_Roland
Please try to clean up your system and remove everything ESP-IDF-related (including all environment variables you've set).
Run the installer again and select the option of installing the built-in Python 3.11. Save the installation log and share it if you still encounter the issue.
I have seen similar many times. My way of fixing these things in Eclipse is:
delete entirely the .espressife folder under user.
Then reinstall the tools. I prefer using the prior downloaded IDF version from local location as source, works fine. Wait until it finishes, it needs quite a while.
Delete the build folder of your project.
Delete the debug configuration in eclipse.
Restart eclipse.
Create a new debug configuration for your project (don't forget to select the correct destination chip)
compile your project
rebuild the index (watch the progress, takes a while until all reg flags disappear)
restart eclipse
It should work now
ahh and stay away from any IDF 5.x there is something utterly wrong with it
Restart eclipse.
restart eclipse
It should work now
Users browsing this forum: No registered users and 59 guests
