UPPERCASE and lowercase
I'm only a beginner in C++ programming
Perhaps the question is very stupid, but nevertheless, I can't find how to translate a string into upper or lower case.
toupper() - not work, throws an error
std::uppercase() - std undeclared
on github - no same issues
on this forum - no same questions
How I can use standart libraries to convert char array to uppercase?
Re: UPPERCASE and lowercase
#include <string>
void makeUpper(std::string& str) {
for(auto& c : str) {
c = std::toupper(c);
Thak you!
I tired
and
with your code
, but if I use , I got
I use this code in a component with cMake:
I Try to add into PRIV_REQUIRES section, but it triggers an error...
And if I use #include <string.h> then I got this
Also I turn on formatter and it changed code like this
with the same error.
I do not understand what I doin wrong.
I tired
#include <string.h>
#include <string>
#include <string>
fatal error: string: No such file or directory
idf_component_register(SRCS "wifi.c"
PRIV_REQUIRES esp_wifi esp_event nvs
INCLUDE_DIRS ".")
string
error: expected ')' before '::' token
30 | void makeUpper(std::string& str) {
void makeUpper(std::string &str)
for (auto &c : str)
Maybe because "string" is CPP, and my file is wifi.c?
Yes, if you want to use C++ (including std::string) the source file has to be named ".cpp".
So, I corrected code like this
void to_upper(char *str, char *out_str)
for (int i = 0; i < strlen(str); i++)
out_str[i] = toupper(str[i]);
char *text = "this is uppercase string!";
char out_text[strlen(text)];
to_upper(text, out_text);
ESP_LOGI("UPPER", "%s", out_text);
I (559) UPPER: THIS IS UPPERCASE STRING!
Great
For better efficiency I suggest a modification, to avoid strlen(str) being evaluated over and over again.
void to_upper(const char *str, char *out_str)
while(*str != 0) {
*out_str = toupper(*str);
++str;
++out_str;
*out_str = 0;
Got It! Done! Thanks a lot again!
Users browsing this forum: Baidu [Spider] and 113 guests
