UPPERCASE and lowercase
sazanof
Postby sazanof » Tue Nov 21, 2023 9:08 am
I'm only a beginner in C++ programming
Perhaps the question is very stupid, but nevertheless, I can't find how to translate a string into upper or lower case.
toupper() - not work, throws an error
std::uppercase() - std undeclared
on github - no same issues
on this forum - no same questions
How I can use standart libraries to convert char array to uppercase?
MicroController
Re: UPPERCASE and lowercase
Postby MicroController » Tue Nov 21, 2023 3:27 pm
#include <string>
void makeUpper(std::string& str) {
    for(auto& c : str) {
        c = std::toupper(c);
sazanof
Postby sazanof » Tue Nov 21, 2023 3:54 pm
Thak you!
I tired
#include <string.h>
and
#include <string>
with your code
, but if I use
#include <string>
, I got
fatal error: string: No such file or directory
I use this code in a component with cMake:
idf_component_register(SRCS "wifi.c"
                       PRIV_REQUIRES esp_wifi esp_event nvs
                       INCLUDE_DIRS ".")
I Try to add
string
into PRIV_REQUIRES section, but it triggers an error...
And if I use #include <string.h> then I got this
error: expected ')' before '::' token
   30 | void makeUpper(std::string& str) {
Also I turn on formatter and it changed code like this
void makeUpper(std::string &str)
    for (auto &c : str)
with the same error.
I do not understand what I doin wrong.
sazanof
Postby sazanof » Tue Nov 21, 2023 4:00 pm
Maybe because "string" is CPP, and my file is wifi.c?
MicroController
Postby MicroController » Tue Nov 21, 2023 4:24 pm
Yes, if you want to use C++ (including std::string) the source file has to be named ".cpp".
sazanof
Postby sazanof » Wed Nov 22, 2023 5:57 pm
So, I corrected code like this
void to_upper(char *str, char *out_str)
    for (int i = 0; i < strlen(str); i++)
        out_str[i] = toupper(str[i]);
char *text = "this is uppercase string!";
    char out_text[strlen(text)];
    to_upper(text, out_text);
    ESP_LOGI("UPPER", "%s", out_text);
I (559) UPPER: THIS IS UPPERCASE STRING!
MicroController
Postby MicroController » Wed Nov 22, 2023 11:37 pm
Great :)
For better efficiency I suggest a modification, to avoid strlen(str) being evaluated over and over again.
void to_upper(const char *str, char *out_str)
  while(*str != 0) {
    *out_str = toupper(*str);
    ++str;
    ++out_str;
  *out_str = 0;
sazanof
Postby sazanof » Sat Nov 25, 2023 7:01 pm
Got It! Done! Thanks a lot again! :)
Users browsing this forum: No registered users and 127 guests
