ESP32 Direct coax wi-fi connection
Jeff Addy
Postby Jeff Addy » Tue Oct 24, 2023 9:09 pm
I want to connect two ESP32 DevKits with an external antenna connector using coax cable. Is it possible to directly connect them without an attenuator? I have them working with two 30 Db attenuators and a T to connect a tinySA and I am getting around -25 dBm at the T. I am using ESP_NOW and Arduino for my program and have not found a way to change the TX power output. I have tried WiFi.setTxPower(WIFI_POWER_2dBm); in the setup but it doesn't change the power output when using ESP_NOW. Any help would be greatly appreciated.
thezcx
Re: ESP32 Direct coax wi-fi connection
Postby thezcx » Fri Nov 17, 2023 2:17 am
Which model do you use?
Jeff Addy
Postby Jeff Addy » Fri Nov 17, 2023 4:44 pm
HiLetgo ESP32-DevKitC-V4 with ESP32-WROOM-32U Core Board.
thezcx
Postby thezcx » Mon Dec 11, 2023 12:56 am
Remove the connector from PCB and solder mid to mid shield to any side of it. I'm using many in this way
Jeff Addy
Postby Jeff Addy » Mon Dec 11, 2023 2:39 am
Thank you for your response. Do you connect them directly or use an attenuator?
Craige Hales
Postby Craige Hales » Mon Dec 11, 2023 3:20 am
@thezcx - Can you post a picture showing what you are doing? Sounds interesting.
I've used this on a wroom32 (pcb antenna) with a streaming wifi web socket:
static int8_t const sPowers[] = {8, 20, 28, 34, 44, 52, 56, 60, 66, 72, 80};
        ESP_ERROR_CHECK_WITHOUT_ABORT(esp_wifi_set_max_tx_power(sPowers[p]));
The value 8 works over very short distances (10 feet maybe) and gives me a lower ADC noise than 52 to 80. I'm pretty sure the wifi tx is getting into the sensor.
Craige
Users browsing this forum: No registered users and 26 guests
