ESP32 zigbee
ESP32 zigbee
We plan to design an application that allows connecting lamps (Philips HUE Zigbee) using an ESP32-S3 or ESP32-C6 module through the Zigbee protocol.
Are there any code examples for using the Zigbee protocol with the ESP32?
Re: ESP32 zigbee
The devices that provide Zigbee (C6, H2) are not yet fully supported in arduino-esp32.
However, if you download 3.0.0-alpha, you should be able to program it with code from the esp32-zigbee-sdk. https://github.com/espressif/esp-zigbee ... b_switch.c
Change app_main() to setup(), and you will probably need to change the assignments to config into two individual lines instead of the C-style struct assignment.
Re: ESP32 zigbee
On further inspection, this is a very convoluted library. I'll give it a shot, since this does need to be integrated, but it is not going to be as simple as putting the sdk in the sketch folder and compiling.
Re: ESP32 zigbee
We need to establish a Zigbee connection between the Hue products made by Philips and the ESP32, is it possible to use ESP-IDF and ESP32-H2 ? any help pls.
Re: ESP32 zigbee
I haven't found any examples that show you how to use zigbee between the ESP32-H2 module and other devices, pls any help.
Re: ESP32 zigbee
You will need to explain better what you mean. There are examples of using the esp as a gateway, or as an end device (light bulb).
Re: ESP32 zigbee
We need to use ESP32-H2 as a gateway for zigbee connexion with other devices like bulb.
Users browsing this forum: Bing [Bot] and 41 guests
