Largest contiguous RAM for HEAP
rma-31
Postby rma-31 » Tue Oct 17, 2023 3:30 pm
On ESP32:
Is there any way to tell malloc to first use memory fragments for heap allocation from the D/IRAM region instead of the DRAM region?
It seems to first consume the DRAM which in turn reduces the size of the largest available contiguous block.
This disallows some critical allocations in my application later on.
Thx for any help :)
username
Re: Largest contiguous RAM for HEAP
Postby username » Wed Oct 18, 2023 2:26 am
Have you tried menuconfig ?
rma-31
Postby rma-31 » Wed Oct 18, 2023 4:59 am
Which entries in menuconfig? I don't want to place code in the PSRAM, there is an option to allow malloc to use PSRAM, but that is RAM is much slower.
Any hints? Thx :)
Alberk
Postby Alberk » Wed Oct 18, 2023 5:39 am
Refer to this for memory allocation https://docs.espressif.com/projects/esp ... alloc.html
rma-31
Postby rma-31 » Wed Oct 18, 2023 7:39 am
That's a good resource for heap analysis.
Unfortunately nothing is said about heap fragmentation and how to best avoid it in order to get a large as possible contiguous block.
Any more ideas? :)
MicroController
Postby MicroController » Wed Oct 18, 2023 8:48 am
General recommendation: Reduce the number of allocations from the heap.
- Use the stack/local variables instead of heap when possible
- Use statically allocated variables
- Avoid reallocations/resizing of allocations (C++ string concatenation, std::vector, ...)
- Allocate one larger block instead of multiple smaller ones.
Alberk
Postby Alberk » Wed Oct 18, 2023 9:03 am
Any more ideas? :)
This should get the largest free block for the different memory types.
size_t heap_caps_get_largest_free_block(uint32_t caps)
rma-31
Postby rma-31 » Wed Oct 18, 2023 9:07 am
These are good strategies, I guess there are no possibilities to change the heap allocation strategy of malloc to first get D/IRAM and then switch to DRAM, reason ist that the DRAM section is larger than the D/IRAM section.
So if malloc would first allocate from D/IRAM, the large contiguous block from DRAM would still be available.
Is there any possibility to achieve this?
Alberk
Postby Alberk » Wed Oct 18, 2023 9:10 am
[/quote]
This will allow you to achieve the RAM allocation by hierarchy https://docs.espressif.com/projects/esp ... _t6size_tz
rma-31
Postby rma-31 » Wed Oct 18, 2023 9:17 am
heap_caps_malloc_prefer
only allows to separate internal from external (PSRAM) memory, but not DRAM from D/IRAM as far as I know.
For my application it is even more difficult as I use std::unique_ptr and would possible have to reimplement the allocator of std::unique_ptr.
Thanks for your help!
Users browsing this forum: MicroController and 184 guests
