ESP32-C3 from LCSC faulty?
Re: ESP32-C3 from LCSC faulty?
Postby ESP_Sprite » Thu Oct 12, 2023 2:05 am
@hristesp: what happens when you force GPIO9 to ground while powering on the ESP? Can you program it then?
cyber_v1
Postby cyber_v1 » Sat Oct 14, 2023 12:20 pm
Interesting. I used a bare ESP32-C3 chip in my design (no space for the module on the board) and ordered the PCB and assembly from JLCPCB. It worked out of the box. Even the 32kHz crystal works (initially I thought it was a hardware issue but it turned out I was dumb and it was a configuration issue).
hristesp
Postby hristesp » Mon Oct 16, 2023 10:46 am
@cyber_v1 very interesting. May I ask how you interfaced with the chip? Was it over USB or UART/JTAG? Do you have a date code?
I removed the front cap of our modules and found the units that do not function were manufactured in 2023, while the working units were made in 2021. On the front of the module the working units have XXN4 while the recent non-functioning ones have M4N4.
cyber_v1
Postby cyber_v1 » Thu Nov 02, 2023 12:38 pm
@hristesp I'm sorry for the late answer.
The interface is built-in USB.
One of the chips reads
ESP32-C3
152023
FH4P3L774R
AE02P0VR24
ramier
Postby ramier » Sat Apr 20, 2024 9:03 am
I am having the same issues with ESP32C3 M4N4 modules. See https://esp32.com/viewtopic.php?f=12&t=39450&p=130974 does anyone have a solution?
Users browsing this forum: GeoffL, Majestic-12 [Bot] and 39 guests
