esp-tls-mbedtls: mbedtls_ssl_setup returned -0x7F00
mmmunir966
Postby mmmunir966 » Mon Nov 28, 2022 10:20 am
I am trying to build https communication alongwith an I2C based RTC. I have integrated custom .pem files for SSL certificate verification. When the sensor is plugged out on I2C driver, the SSL communication works fine and data is transmitted successfuly to the server.
I am getting below errors when I connect the sensor on I2C port. I tried to change the SDA and SCL pins, but the issue remains the same. I earched for this issue on different forums but could not get even a single clue.
The errors are
W (93495) HTTP_CLIENT: Setting https configs.
W (93505) HTTP_CLIENT: Setting config->use_global_ca_store.
E (93555) esp-tls-mbedtls: mbedtls_ssl_setup returned -0x7F00
E (93555) esp-tls: create_ssl_handle failed
E (93555) esp-tls: Failed to open new connection
E (93565) TRANSPORT_BASE: Failed to open a new connection
E (93575) HTTP_CLIENT: Connection failed, sock < 0
I (93575) DataUploadClient: HTTP_EVENT_ERROR
E (93585) DataUploadClient: Error perform http request ESP_ERR_HTTP_CONNECT
I (93585) DataUploadClient: HTTP_EVENT_DISCONNECTED
I have configured the HTTPs as below.
            .url = host_url.c_str(),
            .port = DEFAULT_SSL_PORT,
            .cert_pem = (const char *)tls_certificate_bundle,
            .cert_len = tls_certificate_bundle_size,
            .method = HTTP_METHOD_POST,
            .event_handler = _http_event_handler,
            .transport_type = HTTP_TRANSPORT_OVER_SSL,
            .use_global_ca_store = true,
        esp_http_client_handle_t client = esp_http_client_init(&config);
        esp_http_client_set_header(client, "content-type", "application/x-protobuf");
        esp_http_client_set_post_field(client, post_data.c_str(), post_data.size());
        esp_err_t err;
        do
            err = esp_http_client_perform(client);
        } while (err == ESP_ERR_HTTP_EAGAIN);
        if (err == ESP_OK)
            ESP_LOGI(TAG, "HTTPS Status = %d, content_length = %d",
                     esp_http_client_get_status_code(client),
                     esp_http_client_get_content_length(client));
        else
            ESP_LOGE(TAG, "Error perform http request %s", esp_err_to_name(err));
Any help would be much appreciated.
mmmunir966
Re: esp-tls-mbedtls: mbedtls_ssl_setup returned -0x7F00
Postby mmmunir966 » Mon Nov 28, 2022 12:53 pm
After doing some more experiments, It seems the issue with the heap memory. The call to perform data upload takes around 38Kb of heap memory, so when the available memory is less than 38kb, it fails to validate the SSL certificates.
The 2nd issue found is timeout. I have multiple tasks running and if context switching happens between the tasks, it gives timeout error.
mmmunir966
Postby mmmunir966 » Tue Nov 29, 2022 12:17 pm
Now, I am getting this error. Anyone please help.
E (546560) esp-x509-crt-bundle: PK verify failed with error FFFFBD70
E (546560) esp-x509-crt-bundle: Failed to verify certificate
E (546560) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x3000
E (546570) esp-tls: Failed to open new connection
E (546570) TRANSPORT_BASE: Failed to open a new connection
E (546580) HTTP_CLIENT: Connection failed, sock < 0
I (546590) DataUploadClient: HTTP_EVENT_ERROR
E (546590) DataUploadClient: Error perform http request ESP_ERR_HTTP_CONNECT
Vikass
Postby Vikass » Sat Sep 30, 2023 6:55 am
Hello @mmmunir966,
Has your issue been resolved?
I am trying to build MQTTS communication and encountered the same issue when connecting to MQTT over SSL.
  1. E (109296) esp-tls-mbedtls: mbedtls_ssl_setup returned -0x7f00
  2. E (109296) esp-tls: create_ssl_handle failed
  3. E (109296) esp-tls: Failed to open new connection
  4. E (109306) TRANS_SSL: Failed to open a new connection
  5. E (109316) MQTT_CLIENT: Error transport connect
Below are the details of my MQTTs structure:
esp_mqtt_client_config_t mqtt_cfg = {
      .uri = "mqtts://mqtts.qwertytest.in:8883",
      .username = "test",
      .password = "test@123",
      .client_cert_pem = (const char *)client_pem_crt_start,
      .client_key_pem = (const char *)client_key_start,
      .cert_pem = (const char *)ca_pem_start,
Any help would be greatly appreciated. :)
mtraven
Postby mtraven » Thu May 09, 2024 2:56 am
were YOU able to resolve it? I'm hitting the exact same set of messages.
Users browsing this forum: Corand, Google [Bot] and 104 guests
