How to print the value of a number in a http server (Arduino ESP32)
Pyshco
Postby Pyshco » Tue Jul 25, 2017 6:43 pm
This little server give to us a ip, wich one we will be using as a URL for example: (http://10.0.0.1), once we are there we can play with LED's and stuff, So, the question here is : this use a GPIO to capture a ADC value, this value is on the Serial monitor but it isn't in the page!, How can i put that value in the page?
Here is the code:
/*Using the ESP-WROOM-32*/
#include <WiFi.h>
const char* ssid     = "CLAROQNK37";
const char* password = "9j98g4NuEaq496Yk";
WiFiServer server(80);
const int analogPin = 32;  // Analog input pin , ours is connected to YL-83
int sensorValue = 0;
//4095 => 3.3
// ADC * 3.3 / 4095 = v
void setup()
    Serial.begin(115200);    // Baud Rate
    pinMode(5, OUTPUT);      // Green LED
    pinMode(4, OUTPUT);      // Yellow LED
    pinMode(12,OUTPUT);      // Buzzer
    delay(10);
    // We start by connecting to a WiFi network
    Serial.println();
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    while (WiFi.status() != WL_CONNECTED)
        delay(100);
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected.");
    Serial.println("IP address: ");
    server.begin();
int value = 0;
void loop()
 WiFiClient client = server.available();   // listen for incoming clients
  if (client)                                // if you get a client,
    Serial.println("New Client.");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected())              // loop while the client's connected
      if (client.available())               // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n')                      // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0)
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("HTTP/1.1 200 OK");
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.print("<head><title>Test Led http protocol</title></head>");
            client.print("<center><h1><b>ESP32 Web Control!!</b></h1></center>");
            client.print("<center><p><b>GREEN LED</b><a href=\"ON1\"><button>ON</button></a>&nbsp;<a href=\"OFF1\"><button>OFF</button></a></p></center>");
            client.print("<center><p><b>Yellow LED</b><a href=\"ON2\"><button>ON</button></a>&nbsp;<a href=\"OFF2\"><button>OFF</button></a></p></center>");
            client.print("<center><h1>Effects!!!!</h1></center>");
            client.print("<center><p>Blink<b>(2 Secs Aprox)</b><a href=\"BLINK\"><button>ON</button></center>");
            client.print("<center><p>Wave<b>(2 Secs Aprox)</b><a href=\"WAVE\"><button>ON</button></center>");
            client.print("<center><h1>Buzzer!!1</h1></center>");
            client.print("<center><p>lil bip!<b>(1 Sec)</b><a href=\"BIP\"><button>ON</button></center>");
            client.print("<p>Value</p>");
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
            break;
          else
          {    // if you got a newline, then clear currentLine:
            currentLine = "";
        else if (c != '\r') // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /ON" or "GET /OFF":
        if (currentLine.endsWith("GET /ON1"))
          digitalWrite(5, HIGH);// GET /ON turns the LED on
        if (currentLine.endsWith("GET /OFF1"))
          digitalWrite(5, LOW);// GET /OFF turns the LED off
        if (currentLine.endsWith("GET /ON2"))
          digitalWrite(4, HIGH);// GET /ON turns the LED on
        if (currentLine.endsWith("GET /OFF2"))
          digitalWrite(4, LOW);// GET /OFF turns the LED off
        if (currentLine.endsWith("GET /BLINK"))
          delay(500);
          delay(500);
          delay(500);
          delay(500);
        if (currentLine.endsWith("GET /WAVE"))
          delay(500);
          delay(500);
          delay(500);
          delay(500);
        if (currentLine.endsWith("GET /BIP"))
          digitalWrite(12, HIGH);
          delay(1000);
          digitalWrite(12, LOW);
          delay(10);
          delay(500);
    // close the connection:
    client.stop();
    Serial.println("Client Disconnected.");
-SensorValue stuff
  sensorValue = analogRead(analogPin);
  double vol = sensorValue * 3.3 / 4095;
  Serial.println(sensorValue);
  Serial.println(vol);
  client.print(sensorValue);
  client.print(vol);
  delay(500);
  client.print(vol,DEC);
  if (vol =< 1.00) //if the voltage is under 1.00 This is for a buzzer
    delay(600);
    if (vol => 3.00) //if the voltage is over 3.00 This is for a buzzer
    delay(100);
-SensorValue stuff
Re: How to print the value of a number in a http server (Arduino ESP32)
Postby ESP_Sprite » Wed Jul 26, 2017 1:59 am
Moved to the Arduino forum.
f.h-f.s.
Postby f.h-f.s. » Wed Jul 26, 2017 8:05 am
uhh you might want to put the adc value you read into one of your GET if-statements or inside your http Response-body.
Your sensor value read is outside the whole http-server stuff. client.stop() was already called when you call client.print(sensorValue);.
Pyshco
Postby Pyshco » Wed Jul 26, 2017 3:27 pm
Thanks pal!, I din't see that mistake.
Users browsing this forum: No registered users and 130 guests
