ESP32S3 Touch Pin Freeze After Grounding
vvw180
Postby vvw180 » Tue Sep 12, 2023 5:07 pm
Hello All,
I was trying the XIAO ESP32S3 touch examples and looks like the readings will freeze after the touch pin is grounded and then touched without grounding. I tried both Arduino IDE examples and IDF examples, same problem.
Does anyone know how to fix this? Or is there a way to “reset” the touch function without resetting the whole system, so that the touch function could still be used after ground is detached from touch pin?
I have tried other ESP32 boards(WROOM) and this does not seem to happen.
Thank you
vw
Users browsing this forum: No registered users and 8 guests
