Hi everyone,
I'm working on a custom PCB board based on ESP32-C3FH4 chip.
HF part doesn't seem to work correctly: softAP is not created until I reduce the TX power to 28 or less (WiFi.setTxPower(WIFI_POWER_7dBm)).
It appears that there is a critical problem with the impedance of the antenna path.
It is 2-layers board (1.6mm thickness, 1oz copper weight) from JLC PCB.
I used typical PIFA antenna (TRACE_ANTENNA_2.4GHZ_15.2MM from SparkFun-RF) and general matching PI filter 2pF - 2.7nH - 2.7pF in 0402 packages. Trace is as short as possible, 16millis and 10millis at chip pin.
When designing I knew that these values are for 4 layer board, but I didn't thought it would be so much critical.
All 5 boards that I have, have the same issue.
I looking for ideas to fix this issue. I could have access to network analyzers but I have no idea how to connect network analyzer to such a small traces.
Best regards,
Michal
ESP32-C3FN4 - Custom board, no WiFi
Re: ESP32-C3FN4 - Custom board, no WiFi
I created an arduino sketch for changing channel and TX power.
I fixed position of a board and fixed position of my USB dongle used as receiver.
I am attaching the measured RSSI for various TX power and channel:
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiAP.h>
#include <iostream>
#include <string>
const char *ssid = "TEST";
const char *password = "TESTTEST";
int channel = -1;
void setup() {
Serial.begin(115200);
while (!Serial);
WiFi.mode(WIFI_AP);
//WiFi.setTxPower(WIFI_POWER_7dBm);
WiFi.setTxPower(WIFI_POWER_5dBm);
updateAccessPoint();
void loop() {
static String inputBuffer = "";
if (Serial.available() > 0) {
char c = Serial.read();
if (c == '\n' || c == '\r') {
processInput(inputBuffer);
inputBuffer = "";
} else {
inputBuffer += c;
void processInput(String input) {
if (input[0] < 0x20) return;
if (input[0] == 'C' || input[0] == 'c') { // Change channel
int value = input.substring(1).toInt();
if (value < 1 || value > 13) {
Serial.println("Invalid channel number. Please enter a value between 1 and 13.");
return;
channel = value;
} else if (input[0] == 'P' || input[0] == 'p') { // Change power
WiFi.setTxPower((wifi_power_t)value);
} else {
Serial.println("Invalid input format. Use C[0-13], P[0-99]");
return;
return;
void updateAccessPoint() {
if (WiFi.softAPdisconnect(true)) {
Serial.println("Access Point disconnected");
delay(100);
WiFi.softAP(ssid, password, channel);
int txPower = WiFi.getTxPower();
Serial.print("TX power: ");
Serial.print(txPower);
Serial.print(", channel: ");
Serial.println(channel);
I removed whole PI filter and it started working fairly good. Still looking for approach to match it correctly
Wrt VNA matching etc: you'd generally use the ESP RF Test Tool for that, iirc it comes with documentation as well. https://www.espressif.com/en/support/do ... ther-tools . From looking at the RF teams desks here, connecting the VNA to the PCB comes down to very thin coax pigtails and good soldering skills, I'm afraid.
Users browsing this forum: Google [Bot] and 38 guests
