Hi everyone
I am developing a led driver for the outdoor using. Temparature is the biggest problem for us. So, i cut the 220 to 12v driver power when the light is off. On the rainmaker app, i added two param (brightness and power) I set the power param as primary assign param.
How Can i disable the brightness ui_toggle when the power param switched off? (like when the device was offline but just brightness)
thank you very much for your answer.
How to enable/disable UI-Toggle access?
- question.jpg (26.08 KiB) Viewed 7688 times
Re: How to enable/disable UI-Toggle access?
Unfortunately, this is not possible right now. Some time back, we had done an experiment with our iOS app to selectively show/hide some params based on values of other params. May be we will revisit that feature.
Users browsing this forum: No registered users and 10 guests
