Look out,I found so many problems with the d2wd!
Re: Look out,I found so many problems with the d2wd!
ok - saw your cross posting
rudi ;-) wrote:@Smartisan
D2WD works well:
have a look here in this thread and this postings
hope this helps further
and please
post the reset reset reset log - this helps us to find out what's going wrong and why.
perhabs you can start simply the read ID prozess
can you communicate with the eMbeddedFlash?
example ( use the newer esptool version please )Code: Select all
make flash_id hello word esptool.py v2.0-beta3 Connecting........____ Detecting chip type... ESP32 Uploading stub... Running stub... Stub running... Manufacturer: 9d Device: 7015 Hard resetting...
thank you
rudi
Thank you! I will try it as you say, but i want to ask if we can supply the esp32 d2wd in 2.8V@200ma? Because the ldo we select work in this voltage and ampere. Apart from you use the lab power supply, we use a battery and ldo to supply power for the esp32 d2wd.Can you suggest some suggestion for the esp32 d2wd? We are disapponited that when we supply the esp32 d2wd 3.5V 3.6V by the dc source but the chip reset reset and reset.But when we just provide the voltage 3.3v the d2wd can work well.
Thank you a lot.
rudi ;-) wrote:Smartisan wrote:ESP_igrr wrote:Supply voltage range is 2.3-3.6V, same as for D0WD.
I think you should test the chip esp32 d2wd , when you supply the voltage over 3.3v the chip will reset reset and reset.
i think there is a big missunderstood here.
first:
the D2WD works very well in the supply 2.3 - 3.6V itself.
BUT
cause D2WD has eMbeddedFlash inside for your firmware,
and this eMbeddedFlash is working only with 1.8 V
and this 1.8 V comes from intern Reguldator of the D2WD ( named VDD_SDIO )
you must set the bootstrap pin "MTDI " high for D2WD
this means, you must connect the "MTDI" pulled up to 3.3V
if you use the flash download tool 3.4.9.2it supported D2WD
but backto your reset resest reset
please post the log for this - there are some infos in the log what is going wrong.
can you please post your reset reset reset log
thank you
rudi
could you please offer the demo board of esp32-d2wd,or how could we get or buy the demo of esp32-dwd?
below is the reset compare to the normal log,please check the problem as soon as possible?
we confirmed that VDD_SDIO is 1.8V,and already pulled high for the pin of MTDI.
hi,i post the reset reset reset log.Can you help me to find the problem,Thank you!
- reset compare to normal.png (39.92 KiB) Viewed 12499 times
hi,i post the reset reset reset log.Can you help me to find the problem,Thank you!Smartisan wrote:rudi ;-) wrote:@Smartisan
D2WD works well:
and please
thank you
rudi
Thank you a lot.
I see you are configuring some GPIOs... which one do you configure after GPIO10?
I see you are configuring some GPIOs... which one do you configure after GPIO10?[/quote]ESP_igrr wrote:I see you are configuring some GPIOs... which one do you configure after GPIO10?
After configure GPIO10.GPIO is not configured any more.After configure GPIO10,"periph_module_enable(PERIPH_I2S0_MODULE)" is called.The followings is reset log and the dump file using "xtensa-esp32-elf-objdump -D -S developing.elf>dump".Could you please give us some suggestions by checking reset log and dump file?
- 401011d8.png (48.95 KiB) Viewed 12482 times
- resetlog.png (23.65 KiB) Viewed 12482 times
- reset_log and dump file.zip
- (5.17 MiB) Downloaded 657 times
Also,
That is not going to work. We recommend at least a 500mA power supply for the ESP32 in our design guidelines.Thank you! I will try it as you say, but i want to ask if we can supply the esp32 d2wd in 2.8V@200ma?
ESP_Sprite wrote:Also,That is not going to work. We recommend at least a 500mA power supply for the ESP32 in our design guidelines.Thank you! I will try it as you say, but i want to ask if we can supply the esp32 d2wd in 2.8V@200ma?
So it must be at least 500ma power supply for the esp32? But why we try it can work in 2.8V-3.3V, and 3.3-3.6V the d2wd would be reset reset reset? The d2wd can work onetime and why it may resset reset reset another time? Is it the current too short cause the problem?
THX
Sorry, but this is wild goose chase unless you post schematic, source code, and exact steps to cause crash.
Users browsing this forum: Bing [Bot] and 67 guests
