Two diferents versions de esp-idf in diferents directories
Nespressif
Postby Nespressif » Wed Aug 23, 2023 5:51 pm
Hi all, I would like to know if I would have any problem if I install another version of esp-idf on my ubuntu computer (I am interested in testing with 5.1 stable). I think that if I save the repository in another directory, for example esp-idf51 and when I want to compile with this version I load the environment variables from that directory (having the correct version of python), I shouldn't have any problem.
This way I could continue working on my projects with the current 4.2 version and try things with 5.1.
Would there be any problem doing this?
locustcox
Re: Two version de esp-idf in diferents directories
Postby locustcox » Thu Aug 24, 2023 1:40 am
I’d highly recommend doing this inside a docker container. I just upgraded a large code base from 4.4 to 5.1 by using a devcontainer that was set up for esp-idf 5.1. Going back and forth between different IDF versions can be a big pain because of all the tool chain and python dependency issues.
ESP_frhr
Re: Two diferents versions de esp-idf in diferents directories
Postby ESP_frhr » Fri Aug 25, 2023 7:13 am
I believe there should be no problem. Tools are properly versioned and python env is also based on esp-idf version. Meaning there should be no collision.
Let's say I have the esp-idf repository already cloned in the esp-idf directory.
git clone --reference esp-idf --single-branch --branch release/v5.1 https://github.com/espressif/esp-idf.git esp-idf-v5.1
This will clone the release/v5.1 branch into esp-idf-v5.1 directory. The --reference option points to an existing esp-idf cloned reposiotry, to speed up the cloning. If you don't need the history, you can also --depth 1 to create a shallow clone. You can do this for multiple branches and have each release in separate repo/directory.
With this just change to the directory/version you want to work with(e.g. esp-idf-v5.1), run
./install.sh && . ./export.sh
and it should be all set. At least this seems to be working for me. HTH
Nespressif
Postby Nespressif » Fri Aug 25, 2023 11:36 am
All right, I'll give it a try, I think it should be fine too.
Thank you both very much for your answers.
Best regards,
Nespressif
Postby Nespressif » Thu Sep 28, 2023 8:59 am
Hi all, for what it's worth, I have managed to install the esp-idf-v5.1 environment in another directory and make it work independently from the 4.2 version I had before. When I want to use one and the other I run . ./export.sh from the directory of the chosen version.
I have had to upgrade python to 3.8 and cmake to 3.29, but everything seems to be fine.
My OS is ubuntu 18.
Greetings to all.
Users browsing this forum: Corand, vritzka and 123 guests
