成功烧录esp_dueros工程,语音识别没有反应?请大佬指点
solin0304
Postby solin0304 » Wed Aug 09, 2023 8:22 am
idf 版本4.4.5 ;开发板esp32s3-box
错误日志如下:
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x178c
load:0x403c9700,len:0xe78
load:0x403cc700,len:0x3184
SHA-256 comparison failed:
Calculated: 098fcf8d59082d09f0fd399339be8babe4374a5d410e36ec035c2dfb7506d897
Expected: 674d1ef682147161ad5d0a2c3004a08ede7148f421d8ecc380873a92d7b265a7
Attempting to boot anyway...
entry 0x403c9980
I (43) boot: ESP-IDF v4.4.5-dirty 2nd stage bootloader
I (43) boot: compile time 15:45:49
I (44) boot: chip revision: v0.1
I (45) qio_mode: Enabling default flash chip QIO
I (51) boot.esp32s3: Boot SPI Speed : 80MHz
I (55) boot.esp32s3: SPI Mode : QIO
I (60) boot.esp32s3: SPI Flash Size : 16MB
I (65) boot: Enabling RNG early entropy source...
I (70) boot: Partition Table:
I (74) boot: ## Label Usage Type ST Offset Length
I (81) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (89) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (96) boot: 2 factory factory app 00 00 00010000 00310000
I (104) boot: 3 model Unknown data 01 82 00320000 0040e000
I (111) boot: End of partition table
I (115) esp_image: segment 0: paddr=00010020 vaddr=3c140020 size=4f8f4h (325876) map
I (173) esp_image: segment 1: paddr=0005f91c vaddr=3fc9c300 size=006fch ( 1788) load
I (174) esp_image: segment 2: paddr=00060020 vaddr=42000020 size=132bc8h (1256392) map
I (370) esp_image: segment 3: paddr=00192bf0 vaddr=3fc9c9fc size=06168h ( 24936) load
I (375) esp_image: segment 4: paddr=00198d60 vaddr=40378000 size=142fch ( 82684) load
I (400) boot: Loaded app from partition at offset 0x10000
I (400) boot: Disabling RNG early entropy source...
I (411) opi psram: vendor id : 0x0d (AP)
I (412) opi psram: dev id : 0x02 (generation 3)
I (412) opi psram: density : 0x03 (64 Mbit)
I (415) opi psram: good-die : 0x01 (Pass)
I (420) opi psram: Latency : 0x01 (Fixed)
I (425) opi psram: VCC : 0x01 (3V)
I (429) opi psram: SRF : 0x01 (Fast Refresh)
I (435) opi psram: BurstType : 0x01 (Hybrid Wrap)
I (440) opi psram: BurstLen : 0x01 (32 Byte)
I (445) opi psram: Readlatency : 0x02 (10 cycles@Fixed)
I (451) opi psram: DriveStrength: 0x00 (1/1)
I (457) spiram: Found 64MBit SPI RAM device
I (461) spiram: SPI RAM mode: sram 80m
I (466) spiram: PSRAM initialized, cache is in normal (1-core) mode.
I (473) cpu_start: Pro cpu up.
I (476) cpu_start: Starting app cpu, entry point is 0x40379508
0x40379508: call_start_cpu1 at D:/esp-idf455/frameworks/esp-idf-v4.4.5/components/esp_system/port/cpu_start.c:147
I (0) cpu_start: App cpu up.
I (768) spiram: SPI SRAM memory test OK
I (777) cpu_start: Pro cpu start user code
I (777) cpu_start: cpu freq: 240000000
I (777) cpu_start: Application information:
I (780) cpu_start: Project name: esp_dueros
I (785) cpu_start: App version: v2.6-dirty
I (790) cpu_start: Compile time: Aug 9 2023 15:48:53
I (796) cpu_start: ELF file SHA256: 9713960456c61164...
I (802) cpu_start: ESP-IDF: v4.4.5-dirty
I (807) cpu_start: Min chip rev: v0.0
I (812) cpu_start: Max chip rev: v0.99
I (817) cpu_start: Chip rev: v0.1
I (822) heap_init: Initializing. RAM available for dynamic allocation:
I (829) heap_init: At 3FCA7C50 len 00041AC0 (262 KiB): D/IRAM
I (835) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DIRAM
I (842) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM
I (848) spiram: Adding pool of 8192K of external SPI memory to heap allocator
I (857) spi_flash: detected chip: gd
I (861) spi_flash: flash io: qio
I (865) sleep: Configure to isolate all GPIO pins in sleep state
I (871) sleep: Enable automatic switching of GPIO sleep configuration
I (878) cpu_start: Starting scheduler on PRO CPU.
I (899) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
I (909) DUEROS: ADF version is v2.6-dirty
E (909) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (919) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (929) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (949) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (959) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (969) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (989) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (999) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1009) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1029) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1039) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1049) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
I (1069) DRV8311: ES8311 in Slave mode
E (1069) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1089) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1099) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1109) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1129) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1139) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1149) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1169) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1179) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1189) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1209) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1219) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1229) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1249) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1259) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1269) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1289) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1299) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1309) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1319) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1339) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1349) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1359) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1379) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1389) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1399) DRV8311: es8311.c:492 (es8311_codec_init): es8311 initialize failed
E (1409) AUDIO_HAL: codec init failed!
E (1419) AUDIO_BOARD: board.c:63 (audio_board_codec_init): Got NULL Pointer
W (1419) I2C_BUS: I2C bus has been already created, [port:0]
E (1429) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1439) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1459) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1469) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1479) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1499) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1509) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1519) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1539) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
I (1549) ES7210: ES7210 in Slave mode
E (1559) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1569) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1579) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1599) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1609) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1619) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1639) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1649) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1659) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1679) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1689) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1699) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1719) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1729) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1739) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1759) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1769) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1779) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1799) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1809) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1819) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1839) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
I (1849) ES7210: Enable ES7210_INPUT_MIC1
E (1849) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1869) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1879) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1889) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1909) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1919) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1929) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
I (1949) ES7210: Enable ES7210_INPUT_MIC2
E (1949) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1959) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1979) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (1989) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (1999) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2019) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2029) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
I (2039) ES7210: Enable ES7210_INPUT_MIC3
E (2049) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2059) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2079) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2089) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2099) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2119) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2129) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2139) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2159) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
W (2149) ES7210: Enable TDM mode. ES7210_SDP_INTERFACE2_REG12: 12
E (2179) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2189) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2199) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2209) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2229) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2239) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2249) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2269) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2279) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2289) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
I (2309) ES7210: config fmt 7C
E (2309) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2319) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2339) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2349) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2359) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2379) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2389) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2399) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2419) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2429) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:170 (i2c_bus_read_bytes):I2C Bus ReadReg Error
E (2439) I2C_BUS: D:/esp-project/esp-adf/components/esp_peripherals/driver/i2c_bus/i2c_bus.c:115 (i2c_bus_write_bytes):I2C Bus WriteReg Error
E (2459) AUDIO_HAL: audio_hal.c:66 (audio_hal_init): audio_hal_init failed
E (2469) AUDIO_BOARD: board.c:55 (audio_board_adc_init): Got NULL Pointer
I (2469) AUDIO_THREAD: The button_task task allocate stack on internal memory
I (2479) AUDIO_THREAD: The esp_periph task allocate stack on internal memory
I (2499) SDCARD: Using 1-line SD mode, base path=/sdcard
I (2499) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (2499) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (2509) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (2539) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (2539) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (2539) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
E (2549) PERIPH_SDCARD: mount sdcard error!
I (3559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (3559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (3559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (3569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (3599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (3599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (3599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
E (3609) PERIPH_SDCARD: mount sdcard error!
I (4559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (4559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (4559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (4569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (4599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (4599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (4599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
E (4609) PERIPH_SDCARD: mount sdcard error!
E (4989) AUDIO_BOARD: Sdcard mount failed
E (4989) DISPATCHER: exe first list: 0x0
I (4989) DISPATCHER: dispatcher_event_task is running...
I (4989) AUDIO_THREAD: The esp_dispatcher task allocate stack on internal memory
E (4999) WIFI_SSID_MANAGER: Fail to get configuration from nvs flash
I (5009) AUDIO_THREAD: The wifi_serv task allocate stack on external memory
E (5009) AUDIO_THREAD: Not found right xTaskCreateRestrictedPinnedToCore.
Please enter IDF-PATH with "cd $IDF_PATH" and apply the IDF patch with "git apply $ADF_PATH/idf_patches/idf_v4.4_freertos.patch" first
E (5029) AUDIO_THREAD: Error creating RestrictedPinnedToCore wifi_serv
E (5039) PERIPH_SERVICE: Create task failed on periph_service_create
E (5049) WIFI_SERV: wifi_service.c:683 (wifi_service_create): Memory exhausted
I (5559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (5559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (5559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (5569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (5599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (5599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (5599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
E (5609) PERIPH_SDCARD: mount sdcard error!
I (510,tid:3fcb0ac8) lightduer_session.c( 44):random = 75933
I (6559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (6559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (6559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (6569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (6599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (6599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (6599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
E (6609) PERIPH_SDCARD: mount sdcard error!
I (7559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (7559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (7559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (7569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (7599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (7599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (7599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (7609) AUDIO_EVT: There is no space in external queue
E (7619) PERIPH_SDCARD: mount sdcard error!
I (8559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (8559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (8559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (8569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (8599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (8599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (8599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (8609) AUDIO_EVT: There is no space in external queue
E (8619) PERIPH_SDCARD: mount sdcard error!
I (9559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (9559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (9559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (9569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (9599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (9599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (9599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (9609) AUDIO_EVT: There is no space in external queue
E (9619) PERIPH_SDCARD: mount sdcard error!
I (10559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (10559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (10559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (10569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (10599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (10599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (10599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (10619) AUDIO_EVT: There is no space in external queue
E (10619) PERIPH_SDCARD: mount sdcard error!
I (11559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (11559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (11559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (11569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (11599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (11599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (11599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (11619) AUDIO_EVT: There is no space in external queue
E (11619) PERIPH_SDCARD: mount sdcard error!
I (12559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (12559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (12559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (12569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (12599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (12599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (12599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (12619) AUDIO_EVT: There is no space in external queue
E (12619) PERIPH_SDCARD: mount sdcard error!
I (13559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (13559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (13559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (13569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (13599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (13599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (13599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (13619) AUDIO_EVT: There is no space in external queue
E (13619) PERIPH_SDCARD: mount sdcard error!
I (14559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (14559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (14559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (14569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (14599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (14599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (14599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (14619) AUDIO_EVT: There is no space in external queue
E (14619) PERIPH_SDCARD: mount sdcard error!
E (15069) WIFI_SERV: wifi_service.c:515 (wifi_service_register_setting_handle): Got NULL Pointer
E (15069) WIFI_SERV: wifi_service.c:573 (wifi_service_set_sta_info): Got NULL Pointer
E (15069) WIFI_SERV: wifi_service.c:557 (wifi_service_connect): Got NULL Pointer
W (15079) AUDIO_BOARD: The board has already been initialized!
I (15089) AUDIO_THREAD: The media_task task allocate stack on external memory
E (15099) AUDIO_THREAD: Not found right xTaskCreateRestrictedPinnedToCore.
E (15109) AUDIO_THREAD: Error creating RestrictedPinnedToCore media_task
E (15119) ESP_AUDIO_CTRL: Error create media_task
E (15129) AUDIO_HAL: audio_hal handle is null
I (15129) MP3_DECODER: MP3 init
W (15139) I2S: APLL not supported on current chip, use I2S_CLK_D2CLK as default clock source
I (15149) I2S: DMA Malloc info, datalen=blocksize=2400, dma_buf_count=3
I (15159) I2S: I2S0, MCLK output by GPIO16
E (15159) ESP_AUDIO_CTRL: Error input parameter. line:1164
I (15169) AUDIO_WRAPPER: Func:duer_audio_setup_player, Line:185, MEM Total:8583595 Bytes, Inter:208539 Bytes, Dram:208539 Bytes
I (15179) AUDIO_WRAPPER: esp_audio instance is:0x0
E (15189) I2S: register I2S object to platform failed
I (15189) I2S: I2S0, MCLK output by GPIO16
I (15199) AUDIO_PIPELINE: link el->rb, el:0x3d802d94, tag:i2s, rb:0x3d8031a8
I (15209) AUDIO_PIPELINE: link el->rb, el:0x3d803060, tag:filter, rb:0x3d8051e8
I (15219) AUDIO_THREAD: The i2s task allocate stack on internal memory
I (15219) AUDIO_ELEMENT: [i2s-0x3d802d94] Element task created
I (15229) AUDIO_ELEMENT: [raw-0x3d802ec4] Element task created
I (15239) AUDIO_THREAD: The filter task allocate stack on external memory
E (15239) AUDIO_THREAD: Not found right xTaskCreateRestrictedPinnedToCore.
E (15259) AUDIO_THREAD: Error creating RestrictedPinnedToCore filter
E (15269) AUDIO_ELEMENT: [filter] audio_thread_create failed
I (15279) AUDIO_PIPELINE: Func:audio_pipeline_run, Line:359, MEM Total:8562587 Bytes, Inter:202355 Bytes, Dram:202355 Bytes
I (15289) AUDIO_ELEMENT: [i2s] AEL_MSG_CMD_RESUME,state:1
W (15289) AUDIO_ELEMENT: [filter] Element has not create when AUDIO_ELEMENT_RESUME
E (15299) AUDIO_PIPELINE: audio_pipeline_resume failed
I (15559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (15559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (15559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (15569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (15599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (15599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (15599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (15619) AUDIO_EVT: There is no space in external queue
E (15619) PERIPH_SDCARD: mount sdcard error!
I (16559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (16559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (16559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (16569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (16599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (16599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (16599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (16619) AUDIO_EVT: There is no space in external queue
E (16619) PERIPH_SDCARD: mount sdcard error!
W (17309) AUDIO_ELEMENT: [i2s-0x3d802d94] Element task destroy timeout[200]
W (17309) AUDIO_ELEMENT: [filter] Element has not create when AUDIO_ELEMENT_TERMINATE
I (17309) AUDIO_WRAPPER: Recorder has been created
I (17319) MODEL_LOADER: The storage free size is 14784 KB
I (17319) MODEL_LOADER: The partition size is 4152 KB
I (17329) MODEL_LOADER: Successfully map model partition
I (17329) AFE_SR: afe interface for speech recognition
I (17339) AFE_SR: AFE version: SR_V220727
I (17339) AFE_SR: Initial auido front-end, total channel: 3, mic num: 2, ref num: 1
I (17349) AFE_SR: aec_init: 0, se_init: 1, vad_init: 1
I (17359) AFE_SR: wakenet_init: 1
MC Quantized wakenet9: wakenet9_v1h24_hilexin_3_0.608_0.615, tigger:v3, mode:2, p:0, (Aug 8 2023 14:21:15)
I (17559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (17559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (17559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (17569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (17579) AFE_SR: wake num: 3, mode: 0, (Aug 8 2023 14:21:15)
W (17589) RECORDER_SR: Multinet is not enabled in SDKCONFIG
I (17589) AUDIO_THREAD: The feed_task task allocate stack on external memory
E (17599) AUDIO_THREAD: Not found right xTaskCreateRestrictedPinnedToCore.
E (17599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (17629) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (17629) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
E (17629) AUDIO_THREAD: Error creating RestrictedPinnedToCore feed_task
W (17649) AUDIO_EVT: There is no space in external queue
E (17659) PERIPH_SDCARD: mount sdcard error!
I (17659) AUDIO_THREAD: The fetch_task task allocate stack on external memory
E (17669) AUDIO_THREAD: Not found right xTaskCreateRestrictedPinnedToCore.
E (17689) AUDIO_THREAD: Error creating RestrictedPinnedToCore fetch_task
I (17699) AUDIO_THREAD: The recorder_task task allocate stack on external memory
E (17699) AUDIO_THREAD: Not found right xTaskCreateRestrictedPinnedToCore.
E (17719) AUDIO_THREAD: Error creating RestrictedPinnedToCore recorder_task
E (17729) AUDIO_RECORDER: Fail to create recorder_task
I (17739) AUDIO_THREAD: The voice_read_task task allocate stack on external memory
E (17749) AUDIO_THREAD: Not found right xTaskCreateRestrictedPinnedToCore.
E (17769) AUDIO_THREAD: Error creating RestrictedPinnedToCore voice_read_task
I (18559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (18559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (18559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (18569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (18599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (18599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (18599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (18619) AUDIO_EVT: There is no space in external queue
E (18619) PERIPH_SDCARD: mount sdcard error!
I (19559) SDCARD: Using 1-line SD mode, base path=/sdcard
I (19559) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (19559) gpio: GPIO[7]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (19569) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
E (19599) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (19599) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
E (19599) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place.
W (19619) AUDIO_EVT: There is no space in external queue
E (19619) PERIPH_SDCARD: mount sdcard error!
该开发版没有SD card 插槽,请问在box板子上怎么验证esp-dueros 在线语音功能
ESP_Xuxin
Re: 成功烧录esp_dueros工程,语音识别没有反应?请大佬指点
Postby ESP_Xuxin » Thu Aug 10, 2023 5:50 am
1:支持 PMOD 拓展,可外接 SD 卡;
2:可以将 SD 的存储改成 spiffs,这个我试过是可以的,就需要有一些代码改动
solin0304
Postby solin0304 » Thu Aug 10, 2023 9:20 am
感谢指点,sd卡模块已购买,请问代码上要如何调整,提示下,小白入门请理解
ESP_Xuxin
Postby ESP_Xuxin » Fri Aug 11, 2023 4:56 am
看下 component 下的 esp32_s3_box相关管脚配置接上
#define FUNC_SDCARD_EN             (1)
#define SDCARD_OPEN_FILE_NUM_MAX    5
#define SDCARD_INTR_GPIO            -1
#define SDCARD_PWR_CTRL             -1
#define ESP_SD_PIN_CLK              GPIO_NUM_13
#define ESP_SD_PIN_CMD              GPIO_NUM_11
#define ESP_SD_PIN_D0               GPIO_NUM_14
你还是用 SD 卡代码不需要调整。
Users browsing this forum: No registered users and 16 guests
