hi even after adding the blob mine have same issuekt88fr wrote: ↑Sun Jul 17, 2022 2:25 pmHi,
I confirm that some S2 Mini clone boards have a routing problem on the C14 ground pad.
After several hours of investigation (and one jeopardized board) the fix is straightforward.
Scratch the ground plane a put a blob between the C14 cap and the ground plane. See attachment.
The WiFi is now rock solid and stable, this make a huge difference.
Cheers.
ESP32-S2 reboots when WiFi is used
Re: ESP32-S2 reboots when WiFi is used
This fix didn't work for me either. I added a larger cap between en and ground by the RST switch which did work.Aditya Kumar wrote: ↑Sun Jul 02, 2023 4:44 pmhi even after adding the blob mine have same issuekt88fr wrote: ↑Sun Jul 17, 2022 2:25 pmHi,
Cheers.
I verified that the EN line voltage was very choppy before this mod using a scope, afterwords it was smooth and no more random resets while using wifi.
https://esp32.com/viewtopic.php?f=19&t= ... 10#p106290
The photo in this post seems to show more bad solder joints.
Resoldering them might help, or simply buy another board.
Users browsing this forum: No registered users and 100 guests
