what is the return value of sockect close() function
policeman0077
Postby policeman0077 » Sat Jul 08, 2023 5:06 pm
I am new to socket programming.
what is the return value of sockect close() function. I could not find in https://docs.espressif.com/projects/esp ... light=lwip.
I always get -1 as return of close(). I have SO_REUSEADDR enabled. Is it safe to reconnect use the same sock after I call close()? Would lwip reuse the sock I just close().
Thank you for any input.
here is the code i wrote:
int tcp_socket_close(asl_socket_t *s)
    int ret=0;
    ret = shutdown(s->socketfd,SHUT_WR);//close write, send fin
    if(ret<0)
        ESP_LOGE(TAG, "tcp_socket_close:fail to SHUT_WR");
    ret = shutdown(s->socketfd,SHUT_RD);//close read
    if(ret<0)
        ESP_LOGE(TAG, "tcp_socket_close:fail to SHUT_RD");
        //return ret;
    ret = close(s->socketfd);//destroy socket
    ESP_LOGI(TAG, "tcp_socket_close: close() return:%d",ret);
    return ret;
I used to check return of socket close() but is always return -1
int tcp_socket_reconnect(asl_socket_t *s)
    int ret=0;
    ret=tcp_socket_close(s);
    // if(ret<0)
    //     ESP_LOGI(TAG, "tcp_socket_reconnect:fail to close socket");
    //     //esp_restart();//fail to close the socket restart
    //     return ret;
    ret=tcp_socket_connect();
    return ret;
Re: what is the return value of sockect close() function
Postby ESP_Sprite » Sun Jul 09, 2023 1:33 am
Close is a posix function; if it returns -1, there has been an error. I think you can do this to get the specifics:
#include <stdio.h>
if (close(..)==-1) {
	perror("close");
policeman0077
Postby policeman0077 » Tue Jan 30, 2024 5:53 pm
#include <stdio.h>
	perror("close");
Thank you. I will try your code. :D
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 88 guests
