not seeing errors on editor
emaayan
Postby emaayan » Sun Jun 18, 2023 7:55 pm
using vs code extension 1.6.3 with idf 5.0.1
i have one project which doesn't show errors
and another project which shows them , i've compared both settings and they are identical, not sure what's going on here
ESP_radurentea
Re: not seeing errors on editor
Postby ESP_radurentea » Mon Jun 26, 2023 8:36 am
This looks like a settings issue. Please make sure your compiler path and IntelliSense mode are set correctly in .vscode/c_cpp_properties.json
If they are indeed the same, maybe try to refresh your IntelliSense from VsCode Command Palette with "C/C++: Reset IntelliSense Database" or try to rebuild the project it my refresh any stale metadata which my be causing the issue.
emaayan
Postby emaayan » Wed Jul 19, 2023 6:21 am
hi.. so this IS a settings issues, some of it has been discussed here https://github.com/espressif/vscode-esp ... issues/672
and here https://github.com/espressif/vscode-esp ... issues/748
there are few problems with new project created with esp-idf, one is that it uses always uses a bad problem matcher in the buiild
task "^[^\\.](.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$"
    "version": "2.0.0",
    "tasks": [
            "label": "Build - Build project",
            "type": "shell",
            "command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py build",
            "windows": {
                "command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py build",
                "options": {
                    "env": {
                        "PATH": "${env:PATH};${config:idf.customExtraPaths}"
            "options": {
                "env": {
                    "PATH": "${env:PATH}:${config:idf.customExtraPaths}"
            "problemMatcher": [
                    "owner": "cpp",
                    "fileLocation": [
                        "relative",
                        "${workspaceFolder}"
                    "pattern": {
                        "regexp": "^\\.\\.(.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
                        "file": 1,
                        "line": 2,
                        "column": 3,
                        "severity": 4,
                        "message": 5
                    "owner": "cpp",
                    "fileLocation": "absolute",
                    "pattern": {
                        "regexp": "^[^\\.](.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
                        "file": 1,
                        "line": 2,
                        "column": 3,
                        "severity": 4,
                        "message": 5
            "group": {
                "kind": "build",
                "isDefault": true
            "label": "Set ESP-IDF Target",
            "type": "shell",
            "command": "${command:espIdf.setTarget}",
            "problemMatcher": {
                "owner": "cpp",
                "pattern": {
                    "regexp": "^(.*):(//d+):(//d+)://s+(warning|error)://s+(.*)$",
                    "file": 1,
                    "line": 2,
                    "column": 3,
                    "severity": 4,
                    "message": 5
            "label": "Clean - Clean the project",
            "type": "shell",
            "command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py fullclean",
            "windows": {
                "command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py fullclean",
                "options": {
                    "env": {
            "options": {
                "env": {
            "problemMatcher": [
                    "owner": "cpp",
                    "fileLocation": [
                        "relative",
                    "pattern": {
                        "file": 1,
                        "line": 2,
                        "column": 3,
                        "severity": 4,
                        "message": 5
                    "owner": "cpp",
                    "pattern": {
                        "file": 1,
                        "line": 2,
                        "column": 3,
                        "severity": 4,
                        "message": 5
            "label": "Flash - Flash the device",
            "type": "shell",
            "command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py -p ${config:idf.port} -b ${config:idf.flashBaudRate} flash",
            "windows": {
                "command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py flash -p ${config:idf.portWin} -b ${config:idf.flashBaudRate}",
                "options": {
                    "env": {
            "options": {
                "env": {
            "problemMatcher": [
                    "owner": "cpp",
                    "fileLocation": [
                        "relative",
                    "pattern": {
                        "file": 1,
                        "line": 2,
                        "column": 3,
                        "severity": 4,
                        "message": 5
                    "owner": "cpp",
                    "pattern": {
                        "file": 1,
                        "line": 2,
                        "column": 3,
                        "severity": 4,
                        "message": 5
            "label": "Monitor: Start the monitor",
            "type": "shell",
            "command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py -p ${config:idf.port} monitor",
            "windows": {
                "command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py -p ${config:idf.portWin} monitor",
                "options": {
                    "env": {
            "options": {
                "env": {
            "problemMatcher": [
                    "owner": "cpp",
                    "fileLocation": [
                        "relative",
                    "pattern": {
                        "file": 1,
                        "line": 2,
                        "column": 3,
                        "severity": 4,
                        "message": 5
                    "owner": "cpp",
                    "pattern": {
                        "file": 1,
                        "line": 2,
                        "column": 3,
                        "severity": 4,
                        "message": 5
            "dependsOn": "Flash - Flash the device"
            "label": "OpenOCD: Start openOCD",
            "type": "shell",
            "presentation": {
                "echo": true,
                "reveal": "never",
                "focus": false,
                "panel": "new"
            "command": "openocd -s ${command:espIdf.getOpenOcdScriptValue} ${command:espIdf.getOpenOcdConfigs}",
            "windows": {
                "command": "openocd.exe -s ${command:espIdf.getOpenOcdScriptValue} ${command:espIdf.getOpenOcdConfigs}",
                "options": {
                    "env": {
            "options": {
                "env": {
            "problemMatcher": {
                "owner": "cpp",
                "pattern": {
                    "regexp": "^(.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
                    "file": 1,
                    "line": 2,
                    "column": 3,
                    "severity": 4,
                    "message": 5
            "label": "adapter",
            "type": "shell",
            "command": "${config:idf.pythonBinPath}",
            "isBackground": true,
            "options": {
                "env": {
                    "PATH": "${env:PATH}:${config:idf.customExtraPaths}",
                    "PYTHONPATH": "${command:espIdf.getExtensionPath}/esp_debug_adapter/debug_adapter"
            "problemMatcher": {
                "background": {
                    "beginsPattern": "\bDEBUG_ADAPTER_STARTED\b",
                    "endsPattern": "DEBUG_ADAPTER_READY2CONNECT",
                    "activeOnStart": true
                "pattern": {
                    "regexp": "(\\d+)-(\\d+)-(\\d+)\\s(\\d+):(\\d+):(\\d+),(\\d+)\\s-(.+)\\s(ERROR)",
                    "file": 8,
                    "line": 2,
                    "column": 3,
                    "severity": 4,
                    "message": 9
            "args": [
                "${command:espIdf.getExtensionPath}/esp_debug_adapter/debug_adapter_main.py",
                "-e",
                "${workspaceFolder}/build/${command:espIdf.getProjectName}.elf",
                "-s",
                "${command:espIdf.getOpenOcdScriptValue}",
                "-ip",
                "localhost",
                "-dn",
                "${config:idf.adapterTargetName}",
                "-om",
                "connect_to_instance"
            "windows": {
                "command": "${config:idf.pythonBinPathWin}",
                "options": {
                    "env": {
                        "PATH": "${env:PATH};${config:idf.customExtraPaths}",
Users browsing this forum: No registered users and 13 guests
