Hi everyone,
i am working on a project using the ESP32-S2, i am communicating with a sensor using I2C. Everything works fine if the I2C connection is kept working. If i try disconnecting and reconnecting the sensor (thus powering it off), when i connect it back again, sometimes the ESP32S2 is capable to restoring the communication back to normal but sometimes it is not.
To explain it better, i added some log into the i2c_master_cmd_begin() function. I report here below the meaningful part of the function:
[Codebox]
// In master mode, since we don't have an interrupt to detective bus error or FSM state, what we do here is to make
// sure the interrupt mechanism for master mode is still working.
// If the command sending is not finished and there is no interrupt any more, the bus is probably dead caused by external noise.
portBASE_TYPE evt_res = xQueueReceive(p_i2c->cmd_evt_queue, &evt, wait_time);
if (evt_res == pdTRUE) {
if (evt.type == I2C_CMD_EVT_DONE) {
if (p_i2c->status == I2C_STATUS_TIMEOUT) {
// If the I2C slave are powered off or the SDA/SCL are connected to ground, for example,
// I2C hw FSM would get stuck in wrong state, we have to reset the I2C module in this case.
i2c_hw_fsm_reset(i2c_num);
clear_bus_cnt[i2c_num] = 0;
ret = ESP_ERR_TIMEOUT;
ESP_LOGI("DEBUG", "COMMAND LINK TIMEOUT"); <------------------------ DEBUG
} else if (p_i2c->status == I2C_STATUS_ACK_ERROR) {
clear_bus_cnt[i2c_num]++;
if (clear_bus_cnt[i2c_num] >= I2C_ACKERR_CNT_MAX) {
ESP_LOGI("DEBUG", "COMMAND LINK FAIL"); <------------------------ DEBUG
ret = ESP_FAIL;
} else {
ESP_LOGI("DEBUG", "COMMAND LINK OK"); <------------------------ DEBUG
ret = ESP_OK;
break;
if (evt.type == I2C_CMD_EVT_ALIVE) {
} else {
break;
}[/Codebox]
Summarizing:
1) when communication is working "COMMAND LINK OK" is printed;
2) when i disconnect the sensor "COMMAND LINK FAIL" is printed;
3) when i reconnect the sensor "COMMAND LINK OK" is printed when the communication is restored correctly, "COMMAND LINK TIMEOUT" is printed when the communication stop working. The only way to restore the communication when "COMMAND LINK TIMEOUT" is output, is to switch on and off the ESP32S2.
i2c issues on i2c_hw_fsm_reset
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- 全国大学生物联网设计竞赛乐鑫答疑专区
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: derveroonibo and 73 guests
- All times are UTC
- Top
- Delete cookies
About Us
