How this process goes is the ESP32 turns on and I go to nRF Connect to see if I can get the services from it.
I press connect on the device, it takes me to the MYDEVICE tab, wait a few seconds, and it will automatically disconnect. Pressing connect then disconnects me almost instantly. After a lot of googling, people say the cause is that the service request is done too quickly and results in the android not getting any services
[Video]: Bluetooth BLE and C++ classes
Re: [Video]: Bluetooth BLE and C++ classes
Additional video is now available ... this one is on the subject if using C++ classes to build a BLE client.
https://www.youtube.com/watch?v=UgI7WRr5cgE
Nice work.
But question,
i saw in your sample that you include "ble.h"
and reference it with BLE::initServer("ImagineServer"); for example.
and i can't find either the include or any other place that could define the static BLE class.
Please Help !
thanks;p
But question,
Please Help !
thanks;p
Howdy,
Unfortunately the moment one makes a video, it immediately becomes out of date. The class called "BLE" was renamed "BLEDevice".
See:
https://github.com/nkolban/esp32-snippe ... ffaabedea0
The good news is that the samples found here:
https://github.com/nkolban/esp32-snippe ... s/BLETests
Should always (hopefully) be consistent with the library.
See:
That's mostly the case for any documentation. Writing it is "easy" maintaining it is very hard.
BLEClientCallbacks miss an empty function for the interface onConnect, or should be pure virtual.
Thank you sir. Excellent. We have made a change to the code base and committed based on your report. Thank you again.
https://github.com/nkolban/esp32-snippets/issues/40
BLEServerCallbacks,
BLECharacteristicCallbacks
Have the same Problem.
Don't know if BLECharacteristicCallbacks should be virtual pure, because you can have mostly only read or write on a characteristic. not all of them are both.
Ho, and i have a conceptual problem with the BLECharacteristic
getValue();
Because not all value you receive are string, the problem is when you receive binary, if there is a 0 you can't get the correct lenght of data you received. Or the callback could give the lenght. But it should be better peharps to get a char* or U8* than a string.
getValue();
Users browsing this forum: Bing [Bot] and 73 guests
