How to switch ESP32 connected network?
Scene with me is my esp32 is connected with first SSID and then I will disconnect it and try to connect it with other networks so it is showing connection process log again connet with first SSID network, not switching to new network why? and how can I do it?
Re: How to switch ESP32 connected network?
Hello anyone? If you don't get I can explain
How do you do that?try to connect it with other networks
So flow is my esp32 connected with network.
then I am disconnecting is with esp_wifi_disconnect()
then setting new wifi router configuration using esp_wifi_set_config()
then esp_wifi_connect();
in monitor is showing finding connecting and again connect with last wifi. not connecting with new wifi.
Users browsing this forum: Google [Bot] and 87 guests
