esp32c3 timer registers
Nikita71
Postby Nikita71 » Fri May 05, 2023 8:01 am
Hello! I want to create a project where I need to use timer 0 to count an unlimited number of bars (time) and vice versa to count down a certain amount of time with a interupt at the end. these regimes must change quite quickly and often.
tried to do it through the idf function, but it didn't work properly, so I switched to registers.
I managed to start the timer itself, but now I stopped at 2 problems:
https://anonymfile.com/eRBZO/photo-2023 ... -49-25.jpg
Problem number 1, I set the timer to reset after 4,000,000 years, but for some reason this does not happen ...
https://anonymfile.com/59WLW/photo-2023 ... -49-30.jpg
Problem number 2 is more important, I still don't know where to add the handler interrupt
#include <Wire.h>
#include <U8g2lib.h>
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g(U8G2_R0, U8X8_PIN_NONE, 6, 7);
#define TIMER0_BASE_ADDR 0x6001F000
volatile uint32_t TIMG_T0LO_REG, TIMG_T0HI_REG;
uint64_t TIMG_T0_REG;
void IRAM_ATTR timer_group0_isr() {
void setup() {
  u8g.begin();
  u8g.enableUTF8Print();
  u8g.setFont(u8g2_font_unifont_t_cyrillic);
  u8g.setFontDirection(0);
  *(volatile uint32_t *)(TIMER0_BASE_ADDR + 13) = 1; // Configure the prescaler 40MHz
  *(volatile uint32_t *) TIMER0_BASE_ADDR |= (1 << 30); // Count up
  *(volatile uint32_t *) TIMER0_BASE_ADDR |= (1 << 29); // AUTORELOAD EN
  /* reload value */
  *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x0018) = 4000000; // TIMG_T0_LOAD 32 bit
  *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x001C) = 0; // TIMG_T0LOADHI_REG 22 bit
  /* alarm value */
  *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x0010) = 30000; // TIMG_T0ALARMLO_REG 32 bit
  *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x0014) = 0; // TIMG_T0ALARMHI_REG 22 bit
  *(volatile uint32_t *) TIMER0_BASE_ADDR |= (1 << 10); // Alarm enable
  *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x0070)  |= (1 << 0); // enable TIMG_T0_INT_ENA interrupt
  *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x0078)  |= (1 << 0); // masked TIMG_T0_INT interrupt
 // *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x007C) |= (0 << 0); // Clear the interrupt
  *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x0020) = 1; // Timer 0 time-base counter reload.
  *(volatile uint32_t *) TIMER0_BASE_ADDR |= (1 << 31); // Enable Timer 0
void loop() {
  u8g.clearBuffer();
  *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x000C) |= (1 << 30); // UPDATE
  TIMG_T0LO_REG = *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x0004); // ticks LO_REG
  TIMG_T0HI_REG = *(volatile uint32_t *)(TIMER0_BASE_ADDR + 0x0008); // ticks HI_REG
  TIMG_T0_REG = (uint64_t)TIMG_T0HI_REG << 32 | TIMG_T0LO_REG; // 32 + 22 = 54 bit
  u8g.setCursor(35, 20);
  u8g.print(TIMG_T0_REG);
  u8g.sendBuffer();
  delay(1000);
Re: esp32c3 timer registers
Postby ESP_Sprite » Fri May 05, 2023 8:38 am
Let's start from the beginning: why didn't the ESP-IDF (or Arduino, for that matter) drivers work for you?
Nikita71
Postby Nikita71 » Fri May 05, 2023 11:02 am
I think that after an interrupt occurs, the timer value is not reset to 0, but the alarm value will simply increase, and I really don't like this work logic. tried to manually reset the value to 0 through the registers, and then set the new value, but it did not work.
Postby ESP_Sprite » Sun May 07, 2023 8:09 am
Why do you think that? As clarified in the docs, when a timer triggers an interrupt by means of an alarm, it can automatically reload the timer to a set value. That value also can be zero.
Users browsing this forum: Majestic-12 [Bot] and 51 guests
