I decided to install ESP-IDF, I use CLion and I work in the project "hello_world". Using CLion, I can build, flash etc. But when I want to use idf.py in the command line it does not work. It only works If I go back to the root directory, run export.bat and then return back to the project path. But this is a very tidious process and surely it should be easier.
Does anybody know what I'm doing wrong?
ESP IDF Environment only works one time
Re: ESP IDF Environment only works one time
This is the expected behavior, you're not doing anything wrong.
You do need to run `export` once per shell.
This comes from a unix mindset where you're actually working in the shell primarily and you may be working on a different project requiring a different idf version in another shell.
I assume in windows you could create a batch file that opens the shell and then runs `export.bat` or something like that?
Users browsing this forum: No registered users and 97 guests
