What are esp-idf supported LCD/TFT displays?
zazas321
Postby zazas321 » Fri Apr 21, 2023 8:07 am
Hello. In my project, I need to add display some information on the lcd or tft display.
In the esp-idf examples I have only found the following:
examples -> peripherals -> lcd ->lvgl
examples -> peripherals -> lcd ->tjpgd
I have launched tjpgd and by inspecting the code I found :
ESP_ERROR_CHECK(esp_lcd_new_panel_st7789(io_handle, &panel_config, &panel_handle));
So from what I understand this example is intended to control st7789 display. I want to choose whatever displayed that is already supported by esp-idf and I can find example code for this display so I spend least amount of time struggling to get it to work.
MicroController
Re: What are esp-idf supported LCD/TFT displays?
Postby MicroController » Fri Apr 21, 2023 11:13 am
bidrohini
Postby bidrohini » Thu Apr 27, 2023 12:25 pm
I think here you will get the names of all the compatible displays: https://github.com/nopnop2002/esp-idf-parallel-tft
One display that is supported by ESPressif-IDF is GC9A01 TFT Rounded Display with LVGL.
jesse_a_b
Postby jesse_a_b » Thu Apr 27, 2023 12:35 pm
There's several libraries on Arduino, TFT_eSPI, MCUFRIEND, GFX, etc.
I haven't found a LCD/TFT display, parallel or serial, that could not work with esp32.
Users browsing this forum: No registered users and 90 guests
