The only way to switch to download mode I've found was to pull some pin physically during power up.
Is there a method to trigger download mode by app?
Is there a way to trigger download boot mode by software?
Re: Is there a way to trigger download boot mode by software?
On which chip? The ESP32 doesn't have this, later chips (S2/S3, C series) sometimes do.
On ESP32 S3 and C3.ESP_Sprite wrote: ↑Mon Apr 17, 2023 1:42 amOn which chip? The ESP32 doesn't have this, later chips (S2/S3, C series) sometimes do.
Thanks for reply. Could you give some example please?
Some code snippet will help a lot.
You can try:
(Note you probably need to include some headers to make that work, I'll leave that to you.)
REG_WRITE(RTC_CNTL_OPTION1_REG, RTC_CNTL_FORCE_DOWNLOAD_BOOT);
esp_restart();
Thanks. It works linke a charm.ESP_Sprite wrote: ↑Sat Apr 22, 2023 3:32 amYou can try:(Note you probably need to include some headers to make that work, I'll leave that to you.)Code: Select all
REG_WRITE(RTC_CNTL_OPTION1_REG, RTC_CNTL_FORCE_DOWNLOAD_BOOT); esp_restart();
#include "esp_system.h"
#include "soc/rtc_cntl_reg.h"
* @brief Software triggering download mode for ESP32 S3
void GoToDownloadMode(void)
esp_restart();
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 116 guests
