will get this lyontek wild horse this week,ESP_Sprite wrote:Good to hear you found the problem. So you have the Lyontek chip working as well now?
btw please check jeroen ( FYI )
txs!
is the KIT/esp-idf up2date for 80 Mhz and psram combine?WiFive wrote:Stable, no crash? Try for 80mhz?
You have another wrover-kit to measure difference in power consumption?
Hi Rudi,rudi ;-) wrote:after you have do 'git checkout feature/psram_malloc'ESP_Sprite wrote:
You can download the beta esp-idf and the toolchain from the usual spots (https://github.com/espressif/esp-idf and https://github.com/espressif/crosstool-NG) but be sure to switch to the psram-compatible branches. For esp-idf, the branch is called 'feature/psram_malloc', for the toolchain it is called 'xtensa-1.22.x-ext_ram_patch'. Note that there are no binaries available for the toolchain, you will need to build it from source. For the different OSses, this is documented here: Linux Mac (Sorry, no Windows support for this yet.). Note: In order to get the psram version, in the instructions at the 'git clone' command, replace 'xtensa-1.22.x' with 'xtensa-1.22.x-ext_ram_patch'. For esp-idf, just clone esp-idf as usual, then do 'git checkout feature/psram_malloc'.
be sure you do this step then :
git submodul update --init
-> toolchain successful
esp8266@esp8266-VirtualBox:~/esp32psram/xtensa-esp32-elf/bin$ xtensa-esp32-elf-gcc --version
xtensa-esp32-elf-gcc (crosstool-NG crosstool-ng-1.22.0-64-g47d56eb) 5.2.0
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-> esp-idf successful
-> hello_world successful
wrover modul still revision 0 can we check on Rev0 wrover the pSRAM?
edit:
tested -
--- ok - no pointer --
/*spiram*/ #include "esp_heap_alloc_caps.h" // #include "../spiram.h" /*** void enable_spi_sram(); ***/ ... uint32_t* buffer = pvPortMallocCaps(4*1024*1024, MALLOC_CAP_SPISRAM); if (buffer==NULL) { printf("could not create SPIRAM Pointer\n"); } else { printf("RAM init done\n"); }
rudi
hi temp4ebtemp4eb wrote: Hi Rudi,
I got a piece of ESP32 WROVER KIT V3 board which had the ESP-WROVER with 4MB of psRAM.
And I had git clone the feature/psram_malloc branch esf-idf code.
The build failed when I open the ext PSRAM features.
It seems need special xtensa-esp32-elf files .
Since I use the Win7 64bit ,so I take the Msys2 as the IDE,which need xtensa-esp32-elf-XX.exe to build the firmware.
I tried to make and build xtensa-1.22.x-ext_ram_patch version crosstool-ng but failed.
I noticed you were using the win7 too.
Could you please send me the xtensa-esp32-elf-XX.exe which could build the psram ESP32 code?
Or Could you please tell me how to get the xtensa-esp32-elf-XX.exe which could build the psram ESP32 code?
Thanx!
[ALL ] Making init.c
[ALL ] i686-build_pc-cygwin-gcc -g -O2 -I. -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/common -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/config -DLOCALEDIR=""/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf/share/locale"" -DHAVE_CONFIG_H -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../include/opcode -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../opcodes/.. -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../readline/.. -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../zlib -I../bfd -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../bfd -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../include -I../libdecnumber -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../libdecnumber -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/gnulib/import -Ibuild-gnulib/import -DTUI=1 -I/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools/include -I/usr/include/python2.7 -I/usr/include/python2.7 -Wall -Wpointer-arith -Wno-unused -Wunused-value -Wunused-function -Wno-switch -Wno-char-subscripts -Wempty-body -Wpointer-sign -Wmissing-prototypes -Wdeclaration-after-statement -Wmissing-parameter-type -Wold-style-declaration -Wold-style-definition -Wformat-nonliteral -c -o init.o -MT init.o -MMD -MP -MF .deps/init.Tpo init.c
[ALL ] rm -f gdb.exe
[ALL ] i686-build_pc-cygwin-gcc -g -O2 -static-libstdc++ -static-libgcc -Wl,--stack,12582912 -o gdb.exe gdb.o xtensa-tdep.o xtensa-config.o solib-svr4.o ser-base.o ser-unix.o ser-pipe.o ser-tcp.o remote.o dcache.o tracepoint.o ax-general.o ax-gdb.o remote-fileio.o remote-notif.o ctf.o tracefile.o tracefile-tfile.o cli-dump.o cli-decode.o cli-script.o cli-cmds.o cli-setshow.o cli-logging.o cli-interp.o cli-utils.o mi-out.o mi-console.o mi-cmds.o mi-cmd-catch.o mi-cmd-env.o mi-cmd-var.o mi-cmd-break.o mi-cmd-stack.o mi-cmd-file.o mi-cmd-disas.o mi-symbol-cmds.o mi-cmd-target.o mi-cmd-info.o mi-interp.o mi-main.o mi-parse.o mi-getopt.o tui-command.o tui-data.o tui-disasm.o tui-file.o tui-hooks.o tui-interp.o tui-io.o tui-layout.o tui-out.o tui-regs.o tui-source.o tui-stack.o tui-win.o tui-windata.o tui-wingeneral.o tui-winsource.o tui.o python.o py-arch.o py-auto-load.o py-block.o py-bpevent.o py-breakpoint.o py-cmd.o py-continueevent.o py-xmethods.o py-event.o py-evtregistry.o py-evts.o py-exitedevent.o py-finishbreakpoint.o py-frame.o py-framefilter.o py-function.o py-gdb-readline.o py-inferior.o py-infevents.o py-infthread.o py-lazy-string.o py-linetable.o py-newobjfileevent.o py-objfile.o py-param.o py-prettyprint.o py-progspace.o py-signalevent.o py-stopevent.o py-symbol.o py-symtab.o py-threadevent.o py-type.o py-unwind.o py-utils.o py-value.o py-varobj.o guile.o elfread.o stap-probe.o dtrace-probe.o posix-hdep.o posix-strerror.o c-exp.o cp-name-parser.o ada-exp.o jv-exp.o d-exp.o f-exp.o go-exp.o m2-exp.o p-exp.o version.o annotate.o addrmap.o auto-load.o auxv.o agent.o bfd-target.o blockframe.o breakpoint.o break-catch-sig.o break-catch-throw.o break-catch-syscall.o findvar.o regcache.o cleanups.o charset.o continuations.o corelow.o disasm.o dummy-frame.o dfp.o source.o value.o eval.o valops.o valarith.o valprint.o printcmd.o block.o symtab.o psymtab.o symfile.o symfile-debug.o symmisc.o linespec.o dictionary.o infcall.o infcmd.o infrun.o expprint.o environ.o stack.o thread.o exceptions.o extension.o filesystem.o filestuff.o inf-child.o interps.o minidebug.o main.o macrotab.o macrocmd.o macroexp.o macroscope.o mi-common.o event-loop.o event-top.o inf-loop.o completer.o gdbarch.o arch-utils.o gdbtypes.o gdb_bfd.o gdb_obstack.o osabi.o copying.o memattr.o mem-break.o target.o target-dcache.o parse.o language.o build-id.o buildsym.o findcmd.o std-regs.o signals.o exec.o reverse.o bcache.o objfiles.o observer.o minsyms.o maint.o demangle.o dbxread.o coffread.o coff-pe-read.o dwarf2read.o mipsread.o stabsread.o corefile.o dwarf2expr.o dwarf2loc.o dwarf2-frame.o dwarf2-frame-tailcall.o ada-lang.o c-lang.o d-lang.o f-lang.o objc-lang.o ada-tasks.o ada-varobj.o c-varobj.o ui-out.o cli-out.o varobj.o vec.o go-lang.o go-valprint.o go-typeprint.o jv-lang.o jv-valprint.o jv-typeprint.o jv-varobj.o m2-lang.o opencl-lang.o p-lang.o p-typeprint.o p-valprint.o sentinel-frame.o complaints.o typeprint.o ada-typeprint.o c-typeprint.o f-typeprint.o m2-typeprint.o ada-valprint.o c-valprint.o cp-valprint.o d-valprint.o f-valprint.o m2-valprint.o serial.o mdebugread.o top.o utils.o ui-file.o user-regs.o frame.o frame-unwind.o doublest.o frame-base.o inline-frame.o gnu-v2-abi.o gnu-v3-abi.o cp-abi.o cp-support.o cp-namespace.o reggroups.o trad-frame.o tramp-frame.o solib.o solib-target.o prologue-value.o memory-map.o memrange.o xml-support.o xml-syscall.o xml-utils.o target-descriptions.o target-memory.o xml-tdesc.o xml-builtin.o inferior.o osdata.o gdb_usleep.o record.o record-full.o gcore.o gdb_vecs.o jit.o progspace.o skip.o probe.o common-utils.o buffer.o ptid.o gdb-dlfcn.o common-agent.o format.o registry.o btrace.o record-btrace.o waitstatus.o print-utils.o rsp-low.o errors.o common-debug.o debug.o common-exceptions.o btrace-common.o fileio.o compile.o compile-c-symbols.o compile-c-types.o compile-object-load.o compile-object-run.o compile-loc2c.o compile-c-support.o inflow.o init.o ../readline/libreadline.a ../opcodes/libopcodes.a ../bfd/libbfd.a -L./../zlib -lz ../libiberty/libiberty.a ../libdecnumber/libdecnumber.a -lncurses -lm -liconv -ldl -lpython2.7 /home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools/lib/libexpat.a ../libiberty/libiberty.a -luser32 build-gnulib/import/libgnu.a
[ALL ] tui-win.o: In function `tui_update_variables':
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:301: undefined reference to `acs_map'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:310: undefined reference to `acs_map'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:307: undefined reference to `acs_map'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:304: undefined reference to `acs_map'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:297: undefined reference to `acs_map'
[ALL ] tui-win.o:/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:313: more undefined references to `acs_map' follow
[ALL ] tui-win.o: In function `tui_refresh_all_win':
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:698: undefined reference to `curscr'
[ALL ] tui-win.o: In function `tui_resize_all':
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:780: undefined reference to `stdscr'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:781: undefined reference to `curscr'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:782: undefined reference to `stdscr'
[ALL ] tui.o: In function `tui_enable':
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui.c:437: undefined reference to `stdscr'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui.c:460: undefined reference to `LINES'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui.c:461: undefined reference to `COLS'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui.c:476: undefined reference to `stdscr'
[ERROR] collect2: error: ld returned 1 exit status
[ALL ] Makefile:1390: recipe for target 'gdb.exe' failed
[ERROR] make[3]: *** [gdb.exe] Error 1
[ALL ] make[3]: Leaving directory '/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/build/build-gdb-cross/gdb'
[ALL ] Makefile:8758: recipe for target 'all-gdb' failed
[ERROR] make[2]: *** [all-gdb] Error 2
[ALL ] make[2]: Leaving directory '/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/build/build-gdb-cross'
[ALL ] Makefile:848: recipe for target 'all' failed
[ERROR] make[1]: *** [all] Error 2
[ALL ] make[1]: Leaving directory '/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/build/build-gdb-cross'
[ERROR]
[ERROR] >>
[ERROR] >> Build failed in step 'Installing cross-gdb'
[ERROR] >> called in step '(top-level)'
[ERROR] >>
[ERROR] >> Error happened in: CT_DoExecLog[scripts/functions@257]
[ERROR] >> called from: do_debug_gdb_build[scripts/build/debug/300-gdb.sh@120]
[ERROR] >> called from: do_debug[scripts/build/debug.sh@35]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@646]
[ERROR] >>
[ERROR] >> For more info on this error, look at the file: 'build.log'
[ERROR] >> There is a list of known issues, some with workarounds, in:
[ERROR] >> 'docs/B - Known issues.txt'
[ERROR]
[ERROR] (elapsed: 133:44.83)
$ ./xtensa-esp32-elf-gcc.exe -v
Using built-in specs.
COLLECT_GCC=./xtensa-esp32-elf-gcc
COLLECT_LTO_WRAPPER=/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf/libexec/gcc/xtensa-esp32-elf/5.2.0/lto-wrapper.exe
Target: xtensa-esp32-elf
Configured with: /home/esp-psram/crosstool-NG/.build/src/gcc-5.2.0/configure --build=i686-build_pc-cygwin --host=i686-build_pc-cygwin --target=xtensa-esp32-elf --prefix=/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf --with-local-prefix=/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf/sysroot --with-sysroot=/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf/sysroot --with-newlib --enable-threads=no --disable-shared --with-pkgversion='crosstool-NG crosstool-ng-1.22.0-64-g47d56eb' --disable-__cxa_atexit --enable-cxx-flags='-fno-exceptions -fno-rtti' --with-gmp=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-mpfr=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-mpc=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-isl=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-cloog=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-libelf=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --enable-lto --enable-target-optspace --without-long-double-128 --disable-libgomp --disable-libmudflap --disable-libssp --disable-libquadmath --disable-libquadmath-support --disable-nls --disable-multilib --enable-languages=c,c++ --disable-libstdcxx-verbose
Thread model: single
gcc version 5.2.0 (crosstool-NG crosstool-ng-1.22.0-64-g47d56eb)
Hi Rudi,rudi ;-) wrote:hi temp4ebtemp4eb wrote: Hi Rudi,
Thanx!
there is just in time officially no windows (*.exe) support for the feature/psram_malloc
you need to build the toolchain under linux and there you can then compile the code.
an other way is, you build the toolchain with posix and cygwin under windows
then you get the *.exe like you wrote.
see my attached log, this runs pretty fine - until last steps - debuger tools, then there is missing something
( have not look deeper just in time - but the next days i will try again )
perhabs ivan/jeroen can look into too - perhabs they see what is missing in the last steps.
its really the final step -- 99.99 prozent was done but i think there is a missing step ..
it was a fast try - but will try again slower next days
it is not 100 prozent finished -
so just in time - you must build the toolchain under linux.
(I am unfortunately for 1 1/2 weeks (summer flu)
Can not be as I would like.)
if the cygwin build is 100 prozent successful then i will upload the toolchain -
and write the steps in windows for build it with cygwin ( posix )
hope this helps?!
rudi
Users browsing this forum: No registered users and 63 guests
