Using an esp32-c3 module (Ai-Thinker one), I can use native usb either in run mode or DFU mode.
With an esp32-s2-solo (a module not a kit), I can see the device in /dev only in DFU mode, not in RUN mode.
I have a RC network (10kohm to Vcc/1uF to GND).
I enter DFU mode by connecting IO0 to GND then EN to GND, releasing GND and then IO0.
IO46 is connected to GND. I can see /dev/cu.usbmodem01 and /dev/tty.usbmodem01.
For RUN mode, I let IO0 not connected since datasheet says "Don’t-care".
I don't see any device in /dev
I'm using a Macbook Pro with v11.7.5 (Big Sur).
But I think this is not important.
What I'm I doing wrong?
Is esp32-s2-solo really supporting native USB?
EDIT: I must add that the Soc is in RUN mode when I have this problem. Blink app works fine.
D+ is connected to IO20 and D- to IO19. I have trie with a second esp32-s2-solo and it's the same.
Native USB issue on an esp32-s2-solo module (not kit)
Re: Native USB issue on an esp32-s2-solo module (not kit)
DFU 'run' mode needs support in the app. If you use esp-idf, using menuconfig to set the logging console to CDC/ACM should enable that.
[SOLVED] Re: Native USB issue on an esp32-s2-solo module (not kit)
@ESP_Sprite thanks, it works!
Users browsing this forum: Bing [Bot] and 48 guests
