espidf.steup.start not found in vscode
emaayan
Postby emaayan » Sun Mar 05, 2023 6:19 pm
hi.. i'm trying to configure vscode with espressif plugin and when i do, i get the error of espidf.setup.start not found
I've used the universal online installer 2.2.0 and i have the c:\espressif path
ESP_radurentea
Re: espidf.steup.start not found in vscode
Postby ESP_radurentea » Thu Mar 09, 2023 8:56 am
Hi emaayan,
I would suggest to make a clean installation of ESP-IDF, using the ESP-IDF INSTALLER Tool 2.3 and try to go through our VS Code extension's Installation guide
Let me know if you need further assistance!
beryllium
Postby beryllium » Mon Mar 20, 2023 6:06 pm
I have the same problem, which seems to me to have appeared with version 1.6.0 of the plugin. After installing the plugin, I am unable to perform the configuration. I have no problem with Eclipse environment or command line, only integration in VS code fails. The solution you suggest doesn't fix the problem. I tried a clean installation: Espressif IDE + VSCODE, but the trouble is always alive! The message is espIdf.setup.start not found. My question, where should this command/file be? With the previous version of the plugin, I had no problem.
Thank for your help.
Here are my Env related to Espressif:
ESP_IDF_VERSION=5.0
IDF_CCACHE_ENABLE=1
IDF_PATH=D:\Espressif\frameworks\esp-idf-v5.0
IDF_PYTHON_ENV_PATH=d:\Espressif\python_env\idf5.0_py3.8_env
IDF_TOOLS_PATH=d:\Espressif
OPENOCD_SCRIPTS=d:\Espressif\tools\openocd-esp32\v0.11.0-esp32-20221026\openocd-esp32\share\openocd\scripts
PYTHONNOUSERSITE=True
RMAKER_PATH=D:\Espressif\esp-rainmaker
eziasolsk0
Postby eziasolsk0 » Wed Mar 22, 2023 2:15 am
This is a bug of the extension version 1.6.0, I tried 1.5.1, and it works
Users browsing this forum: No registered users and 8 guests
