error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio\\2022\\BuildTools\\VC\\Tools\\MSVC\\14.34.31933\\bin\\HostX86\\x64\\cl.exe' failed with exit code 2
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for gevent
Successfully built esp-windows-curses
Failed to build gevent
ERROR: Could not build wheels for gevent, which is required to install pyproject.toml-based projects
How to solve it?
I have issue about installing ESP-IDF
Re: I have issue about installing ESP-IDF
Exactly what steps did you follow to install ESP-IDF up to the point when you saw that error?
Did you follow the instructions here: https://github.com/espressif/vscode-esp ... install.md when you installed? Those worked for me very nicely.
Users browsing this forum: Baidu [Spider] and 93 guests
