I'm noticed that automatic download through USB-Serial (FTDI) hardware does not work in some circumstances:
- running from guest VM
- Some MacOs system
- running on Host OS, but being called from within a larger GUI (python) program.
I've tried fiddling with the delays in esptool.py reset code without much success.
Does anyone have a more reliable mechanism to trigger automatic downloads?
-a
USB-Serial Lag issues with Automatic Download esp_tool.py
Re: USB-Serial Lag issues with Automatic Download esp_tool.py
There is a previous discussion here which might help: https://esp32.com/viewtopic.php?t=8219
Not sure if there has been further progress from there.
Verified. Markus has a solution in the post above that does work on Linux and resolves the latency issue.RMandR wrote: ↑Sat Jan 28, 2023 2:44 pmThere is a previous discussion here which might help: https://esp32.com/viewtopic.php?t=8219
Users browsing this forum: alkhachatryan, Bing [Bot] and 77 guests
