Hallo
Just installed VSC + IDF 5.0
In the "output" tab I read:
'riscv32-esp-elf-gdb-no-python' is not recognized as an internal or external command,
operable program or batch file.
Command failed: riscv32-esp-elf-gdb-no-python --version
Error checking riscv32-esp-elf-gdb version
Error: Command failed: riscv32-esp-elf-gdb-no-python --version
'xtensa-esp-elf-gdb-no-python' is not recognized as an internal or external command,
Command failed: xtensa-esp-elf-gdb-no-python --version
Error checking xtensa-esp-elf-gdb version
Error: Command failed: xtensa-esp-elf-gdb-no-python --version
I'd like to clear those alarms. How-to?
Thank you and best regards, Sergio
ESP IDF 5.0 - alarms from the "output" tab
Users browsing this forum: Majestic-12 [Bot] and 96 guests
