Good approach to disable WiFi?
Adriano
Postby Adriano » Mon Dec 19, 2022 9:02 am
As the ATMega is always more expensive, there is no reason to use it anymore in projects. Even if you don't need WiFi or BT.
And now my question. On some projects I don't need the WiFi. I can reduce the consumption to 50mA.
I can deactivate the WiFi with:
#include <WiFi.h>
void setup()
  WiFi.disconnect();
  WiFi.mode(WIFI_OFF);
But this code increase the program size [+400kB] and the dynamic memory [+25kB].
I can flash this program and then remove the WiFi lines. But if for any reason the WiFi is active again, the ESP will probably crash if I have only a 100mA power supply.
Is there a better solution to deactivate the WiFi without loosing all this memory?
Thanks.
Adriano
bidrohini
Re: Good approach to disable WiFi?
Postby bidrohini » Mon Dec 19, 2022 10:16 am
Here is a thread that may help: https://esp32.com/viewtopic.php?t=25515
Adriano
Postby Adriano » Thu Dec 22, 2022 3:08 pm
Do you mean, I should write a "lite" WiFi library?
I am able to disable the WiFi, but if I use the library to disable the WiFi, the sketch is much bigger and I loose also 25kb of RAM.
bidrohini
Postby bidrohini » Fri Dec 23, 2022 7:48 pm
In the thread I posted above, I can see this command
esp_err_t results = esp_wifi_stop();
Did you try this?
Adriano
Postby Adriano » Mon Jan 09, 2023 8:21 am
No it doesn't work.
To be able to use this function, I need to use:
esp_wifi_init(cfg);
With this call, I loose all the memory (400kb) on the ESP32.
I will wait for the ESP32-P4 :)
boarchuz
Postby boarchuz » Mon Jan 09, 2023 11:39 am
This is nuts. Don't initialise it. There's nothing to stop.
Adriano
Postby Adriano » Mon Jan 09, 2023 4:06 pm
Oh yes. It seems to work.
But why return an error code if it works?
#include "esp_wifi.h"
void setup()
  esp_wifi_set_mode(WIFI_MODE_NULL);
this will disable the WiFi (I lost only 85kb from the flash and 9kb of RAM).
https://github.com/espressif/esp-idf/bl ... ifi.h#L282
esp_wifi_set_mode returns ESP_ERR_WIFI_NOT_INIT. Why return an error, if we don't need to init it to disable the WiFi?
boarchuz
Postby boarchuz » Mon Jan 09, 2023 4:14 pm
No, don't do anything:
void setup()
You don't need to disable it if you haven't enabled it.
Adriano
Postby Adriano » Mon Jan 09, 2023 4:19 pm
I don't know if the WiFi is enabled...
When I get a new ESP32, the WiFi could be enabled.
I want to disable it, if enabled. Or at least be sure it is disabled.
Postby ESP_Sprite » Tue Jan 10, 2023 12:53 am
It can't be if you don't manually enable it.
Users browsing this forum: No registered users and 28 guests
