Hello good people of espia
I have encountered a weird issue while debugging my software (using jtag ft2232hl), the code is written in C++..
What is happening is when i add the call to "esp_err_t err = esp_http_client_perform (client);"
and start debugging then the output given to me is
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
and being repeated, when i comment out the call to 'esp_http_client_perform' the debug works as proper and i can step through the code
Would love some assistance, Thanks in advance!
Debug controller reset when including a method in source
Re: Debug controller reset when including a method in source
Hi mazorsk, could you check what is printed on the UART output when "Debug controller was reset" is printed in the debugger?
Hi, thank you for the fast reply.. im not sure what you mean by uart monitor (no such window in visualgdb)
i have the openocd output, again - this only happens when i include the mentioned method in the source..
thanks again
C:\Users\trakt\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core\bin\openocd.exe -c "gdb_port 56102" -c "telnet_port 56
101" -f interface/ftdi/esp32_devkitj_v1.cfg -c "adapter_khz 3000" -f target/esp32.cfg -c "echo VisualGDB_OpenOCD_Ready"
Open On-Chip Debugger 0.10.0 (2020-07-22)
Licensed under GNU GPL v2
libusb1 09e75e98b4d9ea7909e8837b7a3f00dda4589dc3
For bug reports, read
adapter speed: 20000 kHz
adapter speed: 3000 kHz
Info : FreeRTOS creation
Info : Listening on port 56101 for telnet connections
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : clock speed 3000 kHz
Info : esp32.cpu0: Target halted, PC=0x4007985E, debug_reason=00000000
Info : Listening on port 56102 for gdb connections
Info : accepting 'gdb' connection on tcp/56102
Info : esp32.cpu0: Target halted, PC=0x40091856, debug_reason=00000001
Info : Set GDB target to 'esp32.cpu0'
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 197 KB
Info : Flash mapping 1: 0x50020 -> 0x400d0020, 739 KB
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.irom' size 740 KB
Info : Using flash bank 'esp32.cpu0.drom' size 200 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
force hard breakpoints
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
** Programming Started **
** Programming Finished **
thanks again
hi, i managed to step into some panic handler (wrapped the client_perform method with try/catch but to no avail)
0x3ffbc83b "abort() was called at PC 0x4015c6a3 on core 0" {97 'a'}
hopes this could help somehow
Hi!
So I Have This Issue too and i know solution for this.
So if you follow tutorial i found https://www.instructables.com/How-to-U ... -an-ESP32/.
First you must add line into platformio.ini
Than if you are using dev-kit you must connect GND cable to GND on ESP32 BOARD but only if you connected ESP-PROG via USB
also you can`t define port like debug_port = COM4 thats making issue.
Also if you downloaded platformio OpenOCD is included
Than You must change board in config i am using board = esp32devupload_protocol = esp-prog
Users browsing this forum: Baidu [Spider] and 79 guests
