Thermostat does not work on GVA
Awantunes
Postby Awantunes » Wed Dec 14, 2022 8:34 pm
Hello guys.
I created a thermostat type device in Rainmaker. It works fine on Rainmaker and Alexa, but it doesn't work properly on GVA. In GVA it is not possible to configure the temperature.
Can anyone who has had this problem help me?
Alexa
WhatsApp Image 2022-12-14 at 17.31.45.jpeg (19.65 KiB) Viewed 3545 times
GVA
WhatsApp Image 2022-12-14 at 17.32.06.jpeg (17.63 KiB) Viewed 3545 times
RainMaker
WhatsApp Image 2022-12-14 at 17.32.22.jpeg (17.5 KiB) Viewed 3545 times
sanketwadekar
Re: Thermostat does not work on GVA
Postby sanketwadekar » Mon Dec 19, 2022 12:37 pm
Can you share a snippet of your code (where you create the device and parameters) here so I can try it on my device?
Awantunes
Postby Awantunes » Mon Dec 19, 2022 6:47 pm
This is the part of my code where I add the device:
Node my_node;
static int gpio_switch = 7;
Device termostato("Controlador de Spa", "esp.device.thermostat", &gpio_switch);
Param parametro_set_temperatura("Temperatura programada", ESP_RMAKER_PARAM_RANGE, value(20), PROP_FLAG_READ | PROP_FLAG_WRITE);
parametro_set_temperatura.addUIType(ESP_RMAKER_UI_SLIDER);
parametro_set_temperatura.addBounds(value(20), value(40), value(1));
Param parametro_temperatura("Temperatura", ESP_RMAKER_PARAM_TEMPERATURE, value(0), PROP_FLAG_READ | PROP_FLAG_WRITE);
my_node = RMaker.initNode("Spa");
termostato.addCb(callback_funcoes);
termostato.addParam(parametro_set_temperatura);
termostato.addParam(parametro_temperatura);
my_node.addDevice(termostato);
RMaker.enableOTA(OTA_USING_PARAMS);
RMaker.enableTZService();
RMaker.enableSchedule();
RMaker.enableScenes();
RMaker.start();
WiFi.onEvent(sysProvEvent);
WiFiProv.beginProvision(WIFI_PROV_SCHEME_BLE, WIFI_PROV_SCHEME_HANDLER_FREE_BTDM, WIFI_PROV_SECURITY_1, pop, service_name);
sanketwadekar
Postby sanketwadekar » Wed Dec 21, 2022 4:33 am
The list of standard devices supported by GVA and Alexa has been updated. https://rainmaker.espressif.com/docs/st ... ml#devices.Here, you can find the additional parameters that need to be added to your code.
Definitions of these parameters can be found here https://rainmaker.espressif.com/docs/st ... parameters
Can you make appropriate changes and try again? If the issue still persists, please upload the complete sketch after changes.
Users browsing this forum: No registered users and 15 guests
