Hi everyone!
I have developed a custom board with the ESP32-D0WD-V3.. I copy exactly the design from the wrover module... But I just use a 16MB flash...
I can program the system perfectly with the Arduino IDE ... But when I open the serial monitor it looks like an endless reset loop.... I can not find any hardware issue... I am very very lost...
Have you ever seen something like that?
Thank you so much in advance for your help!
Best regards!
Custom board: endless reset loop
Re: Custom board: endless reset loop
Can you post the text that appears on the reset loop here? Also, just in case, can you post your schematic?
13:32:53.713 -> configsip: 0, SPIWP:0xee
13:32:53.713 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
13:32:53.713 -> mode:DIO, clock div:1
13:32:53.713 -> load:0x3fff0018,len:4
13:32:53.713 -> load:0x3fff001c,len:1216
13:32:53.713 -> ho 0 tail 12 room 4
13:32:53.713 -> load:0x40078000,len:10944
13:32:53.760 -> load:0x40080400,len:6388
13:32:53.760 -> entry 0x400806b4
13:32:53.760 -> ets Jul 29 2019 12:21:46
Did you try to flash simple empty sketch to see if its hardware or software?
Users browsing this forum: Bing [Bot] and 75 guests
