esp32s3 上电后 第一次esp32s3 软重启报错
yekun1996
Postby yekun1996 » Thu Nov 24, 2022 9:35 am
I (29) boot: ESP-IDF v4.4-dirty 2nd stage bootloader
I (29) boot: compile time 17:08:59
I (29) boot: chip revision: 0
I (31) boot.esp32s3: Boot SPI Speed : 80MHz
I (36) boot.esp32s3: SPI Mode : DIO
I (41) boot.esp32s3: SPI Flash Size : 16MB
I (46) boot: Enabling RNG early entropy source...
I (51) boot: Partition Table:
I (55) boot: ## Label Usage Type ST Offset Length
I (62) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (69) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (77) boot: 2 factory factory app 00 00 00010000 00177000
I (84) boot: End of partition table
I (88) esp_image: segment 0: paddr=00010020 vaddr=3c0d0020 size=2cb5ch (183132) map
I (130) esp_image: segment 1: paddr=0003cb84 vaddr=3fc953d0 size=03494h ( 13460) load
I (133) esp_image: segment 2: paddr=00040020 vaddr=42000020 size=cc680h (837248) map
I (286) esp_image: segment 3: paddr=0010c6a8 vaddr=3fc98864 size=0131ch ( 4892) load
I (287) esp_image: segment 4: paddr=0010d9cc vaddr=40374000 size=113c4h ( 70596) load
I (307) esp_image: segment 5: paddr=0011ed98 vaddr=50000000 size=00010h ( 16) load
I (314) boot: Loaded app from partition at offset 0x10000
I (314) boot: Disabling RNG early entropy source...
I (327) cpu_start: Pro cpu up.
I (327) cpu_start: Starting app cpu, entry point is 0x40375204
0x40375204: call_start_cpu1 at D:/ESP32_IDF/esp-idf-v4.4/components/esp_system/port/cpu_start.c:156
I (306) cpu_start: App cpu up.
I (341) cpu_start: Pro cpu start user code
I (341) cpu_start: cpu freq: 160000000
I (341) cpu_start: Application information:
I (344) cpu_start: Project name: tumblevd
I (349) cpu_start: App version: V04.00.05
I (354) cpu_start: Compile time: Nov 24 2022 17:08:47
I (360) cpu_start: ELF file SHA256: f0a567c278e805f4...
I (366) cpu_start: ESP-IDF: v4.4-dirty
I (372) heap_init: Initializing. RAM available for dynamic allocation:
I (379) heap_init: At 3FCA0158 len 0003FEA8 (255 KiB): D/IRAM
I (385) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM
I (392) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (399) spi_flash: detected chip: gd
I (402) spi_flash: flash io: dio
I (407) sleep: Configure to isolate all GPIO pins in sleep state
I (413) sleep: Enable automatic switching of GPIO sleep configuration
I (420) coexist: coexist rom version e7ae62f
I (425) cpu_start: Starting scheduler on PRO CPU.
I (687) system_api: Base MAC address is not set
I (687) system_api: read default base MAC address from EFUSE
I (687) main: Tumblevd/68B6B322610E/TX
I (687) main: Tumblevd/68B6B322610E/RX
W (697) BT_INIT: esp_bt_controller_mem_release not implemented, return OK
I (697) BT_INIT: BT controller compile version [6881869]
I (707) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12
pll_cap_ext 10
pll_cap_ext 10
pll_cap_ext 10
pll_cap_ext 10
pll_cap_ext 10
pll_cap_ext 10
pll_cap_ext 10
pll_cap_ext 10
pll_cap_ext 10
pll_cap_ext 10
然后WIFI 连接不上
Users browsing this forum: No registered users and 28 guests
