I need helps.
I try to use the sd_card example provided by esp_idf to read a sd card from a adapter.
From unknown reason, I have never been able to make it work.
This is the sd card adapter I got it from Amazon.
https://www.amazon.com/HiLetgo-Adater-I ... ics&sr=1-4
This is the message I got after SPI initiated:
I (344) example: Using SPI peripheral
I (354) gpio: GPIO[5]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (364) sdspi_transaction: cmd=52, R1 response: command not supported
I (414) sdspi_transaction: cmd=5, R1 response: command not supported
W (424) sdmmc_common: sdmmc_init_csd: SDSC card reports capacity=15949824. Limiting to 8388608.
E (424) sdmmc_sd: sdmmc_check_scr: send_scr returned 0x109
E (424) vfs_fat_sdmmc: sdmmc_card_init failed (0x109).
I (434) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
E (444) example: Failed to initialize the card (ESP_ERR_INVALID_CRC). Make sure SD card lines have pull-up resistors in place.
I've tried to map different IO pins, pull up registers. No one works for me.
Please help.
Thanks in advance.
Josh
Never be able to make sd_card example work
Re: Never be able to make sd_card example work
Can you share your ESP-IDF version and how you are connecting the SD Card module to the board?
Be careful about this module power supply. The ESP32 is 3V3 and this modules should work on 5V (Arduino compatible). I think this is the issue.
The version of ESP-IDF is v4.2
The esp-wroom-32 dev board https://www.amazon.com/MELIFE-Developme ... 7a9c0027d0
The SD CARD adapter https://www.amazon.com/HiLetgo-Adater-I ... 218&sr=8-4
The connections:
D19 ---- MISO
D23 ---- MOSI
D18 -----SCK
D5 ---- CS
VIN (5V+) ----VCC
GND ---- GND
The dev board, sd card adapter hardware and the connections work fine on microPython.
But I have never make them work with sd_card_example.c provided in esp-idf.
Thanks,
Josh
The connections:
D19 ---- MISO
D23 ---- MOSI
D18 -----SCK
D5 ---- CS
VIN (5V+) ----VCC
GND ---- GND
Thanks,
Josh
Were you ever able to make sd card work on esp_idf 5.0. Even though on arduino SD card is detected and works, but with esp_IDF i keep getting errors
I set all SPI pins as pull ups, but soon as SPI bus is initialized, all the pullups change from 1 to 0
V bus_lock: dev 4 acquired.
D (2997) spi_master: device4 locked the bus
V bus_lock: SPI dev changed from -1 to 4
V (3007) spi_master: polling trans
V (3017) spi_master: polling trans done
V (3027) spi_master: polling trans
V (3027) spi_master: polling trans done
V (3037) spi_master: polling trans done
D (3037) spi_master: device4 release bus
V (3047) bus_lock: dev 4 released.
V (3047) sdspi_transaction: r1 = 0x7f hw_cmd.r[0]=0xffffffff
D (3057) sdspi_transaction: cmd=55, R1 response: command CRC error
D (3057) sdmmc_cmd: cmd=55, sdmmc_req_run returned 0x109
E (3067) sdmmc_sd: sdmmc_check_scr: send_scr returned 0x109
D (3067) sdmmc_init: sdmmc_card_init: sdmmc_check_scr returned 0x109
E (3077) vfs_fat_sdmmc: sdmmc_card_init failed (0x109).
I (3087) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
E (3087) SD_MMC: Failed to initialize the card (ESP_ERR_INVALID_CRC). Make sure SD card lines have pull-up resistors in place.
Hello,did you find the solution?I have encountered the same problem.
Users browsing this forum: No registered users and 208 guests
