Arduino - Second SPI port for ESP32 S3
StuartsProjects
Postby StuartsProjects » Sat Oct 22, 2022 2:42 pm
I have an ESP32 S3 Wroom 1 Dev Module and the 2.0.5 core whuch has support for the S3.
I can run a SPI device on the standard, default SPI port which you use with SPI.begin()
However, I am trying to get the second SPI port running (pins GPIO35, GPIO36, GPIO37) which the code for the example 'SPI_Multiple_Buses.ino' implies with these lines that it supports the S3;
#if CONFIG_IDF_TARGET_ESP32S2 || CONFIG_IDF_TARGET_ESP32S3
#define VSPI FSPI
#endif
But this produces a repeating error;
E (2115) gpio: gpio_set_level(226): GPIO output gpio_num error
The standard SPI port is working, SCK is active etc, but the second is not.
What is the correct naming or code for the second SPI avaialble SPI port on the S3.
StuartsProjects
Re: Arduino - Second SPI port for ESP32 S3
Postby StuartsProjects » Sat Oct 22, 2022 3:39 pm
Here is the 'SPI_Multiple_Buses.ino' code;
/* The ESP32 has four SPi buses, however as of right now only two of
 * them are available to use, HSPI and VSPI. Simply using the SPI API
 * as illustrated in Arduino examples will use VSPI, leaving HSPI unused.
 * However if we simply intialise two instance of the SPI class for both
 * of these buses both can be used. However when just using these the Arduino
 * way only will actually be outputting at a time.
 * Logic analyser capture is in the same folder as this example as
 * "multiple_bus_output.png"
 * created 30/04/2018 by Alistair Symonds
#include <SPI.h>
// Define ALTERNATE_PINS to use non-standard GPIO pins for SPI bus
#ifdef ALTERNATE_PINS
  #define VSPI_MISO   2
  #define VSPI_MOSI   4
  #define VSPI_SCLK   0
  #define VSPI_SS     33
  #define HSPI_MISO   26
  #define HSPI_MOSI   27
  #define HSPI_SCLK   25
  #define HSPI_SS     32
#else
  #define VSPI_MISO   MISO
  #define VSPI_MOSI   MOSI
  #define VSPI_SCLK   SCK
  #define VSPI_SS     SS
  #define HSPI_MISO   12
  #define HSPI_MOSI   13
  #define HSPI_SCLK   14
  #define HSPI_SS     15
#endif
#define VSPI FSPI
#endif
static const int spiClk = 1000000; // 1 MHz
//uninitalised pointers to SPI objects
SPIClass * vspi = NULL;
SPIClass * hspi = NULL;
void setup() {
  //initialise two instances of the SPIClass attached to VSPI and HSPI respectively
  vspi = new SPIClass(VSPI);
  hspi = new SPIClass(HSPI);
  //clock miso mosi ss
#ifndef ALTERNATE_PINS
  //initialise vspi with default pins
  //SCLK = 18, MISO = 19, MOSI = 23, SS = 5
  vspi->begin();
#else
  //alternatively route through GPIO pins of your choice
  vspi->begin(VSPI_SCLK, VSPI_MISO, VSPI_MOSI, VSPI_SS); //SCLK, MISO, MOSI, SS
#endif
  //initialise hspi with default pins
  //SCLK = 14, MISO = 12, MOSI = 13, SS = 15
  hspi->begin();
#else
  hspi->begin(HSPI_SCLK, HSPI_MISO, HSPI_MOSI, HSPI_SS); //SCLK, MISO, MOSI, SS
#endif
  //set up slave select pins as outputs as the Arduino API
  //doesn't handle automatically pulling SS low
  pinMode(vspi->pinSS(), OUTPUT); //VSPI SS
  pinMode(hspi->pinSS(), OUTPUT); //HSPI SS
// the loop function runs over and over again until power down or reset
void loop() {
  //use the SPI buses
  spiCommand(vspi, 0b01010101); // junk data to illustrate usage
  spiCommand(hspi, 0b11001100);
  delay(100);
void spiCommand(SPIClass *spi, byte data) {
  //use it as you would the regular arduino SPI API
  spi->beginTransaction(SPISettings(spiClk, MSBFIRST, SPI_MODE0));
  digitalWrite(spi->pinSS(), LOW); //pull SS slow to prep other end for transfer
  spi->transfer(data);
  digitalWrite(spi->pinSS(), HIGH); //pull ss high to signify end of data transfer
  spi->endTransaction();
Users browsing this forum: No registered users and 118 guests
