This is an excerpt of my "esp_http_server.h" (ESP-IDF V4.4)
.global_transport_ctx_free_fn = NULL, \
.open_fn = NULL, \
searching www ("https://github.com/espressif/esp-idf") I found a newer version and the excerpt is like that
.enable_so_linger = false, \
.linger_timeout = 0, \
.open_fn = NULL, \
The file "esp-idf-master.zip" is downloadable from "https://github.com/espressif/esp-idf"
1)
is "esp-idf-master" package intended to upgrade an existing installation?
2)
In that case is there a manual that explains howto? I could not find it (neither in the README.md) What is the proper procedure to update my ESP-IDF? Uploading all the new files included in the package "esp-idf-master"?
thank you.
update ESP-IDF with more recent code
Re: update ESP-IDF with more recent code
Please check this page on how to switch to a particular version of ESP-IDF: https://docs.espressif.com/projects/esp ... ng-esp-idf
After updating your esp-idf copy, you need to install the tools for the new version: https://docs.espressif.com/projects/esp ... stallation
If you are on Windows, it is recommended to run the IDF installer for windows and let it create a new copy of ESP-IDF, instead of following the manual steps.
@ ESP_igrr
Following:
https://github.com/espressif/vscode-esp ... install.md
I've downloaded the ESP-IDF 4.4.2 (from Espressif server since I was not able to manage in a similar way by selecting "Github" instead)
But the "esp_http_server.h" (ESP-IDF V4.4.2) is still similar to the former release (ESP-IDF 4.4):
.open_fn = NULL, \
I still need to find out the how-to upload in my environment the version of "esp_http_server.h" part of this package:
"esp_http_server.h" excerpt is like that:
.open_fn = NULL, \
Is that package coherent with ESP-IDF 4.4.2?
Is there a user manual that explains how-to download and install it in an existing ESP-IDF?
Should it be better to select "Github" at release download step (as mentioned here above)?
thank you.
Following:
.open_fn = NULL, \
.open_fn = NULL, \
thank you.
@ ESP_igrr
can you get back to me?
Many thanks, s.
Many thanks, s.
Users browsing this forum: No registered users and 95 guests
